Old 04-17-2002, 05:30 PM   #1
MITCH1914
MITCH1914's Avatar
Post HOW DO I INSTALL A PUSH BUTTON STARTER
i am having trouble with my switch. some times my truck starts and sometimes it does not. if i jiggle the wires behind ignition swich it will start. how can i go around that and put a push button starter in my truck. what do i need to do
MITCH1914 is offline   Reply With Quote
Old 04-17-2002, 06:46 PM   #2
Brian19692
Post
Run a constant hot wire to one post of the push button and another wire from the other post to the "s" terminal of the solenoid.
69 short box 4x4
72 long box
69 Camaro 327 4-speed
71 4x4 suburban, soon to be crew cab short box
87 S-10 V-8 FOR SALE
Des Moines, Iowa
[This message has been edited by Brian19692 (edited April 17, 2002).]
67 short 2wd. FOR SALE
69 long box w/72 grill
Des Moines, Iowa
Brian19692 is offline   Reply With Quote
Old 04-17-2002, 07:26 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
On a side note, unplug your ignition switch, and inspect the actual problem, My old Longhorn started to burn these wires becouse the connection was rusted.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-17-2002, 08:03 PM   #4
Andy4639
Old member
Andy4639's Avatar
Cool
Why not just fix what's wrong. All you need to do is take the switch out of the dash with wires stil on then draw a diagram of the switch and take the wires off and redo them with crimp connectors. I was having the same problem awhile back and did this. I have had nomore problems. Starts everytime now. Also if you take the starter switch out what would you do about all of the accessary wiring off the back of the switch, seems to me it wouldn't be worth the hassel to rewire everything just fix whats there.
Andy
71's Are for ever!!! or 67,68,69,70,72
71 Custome Deluxe,factory tach,tilt for straight drive,gauges,AC,305 HO TPI with 700-R4, lowered 2", 3",17" wheels
www.geocities.com/chevy71tpi/main.html
[URL=http://www.picturetrail.com/Andy4639[/URL]
[This message has been edited by Andy4639 (edited April 17, 2002).]
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-17-2002, 10:58 PM   #5
MITCH1914
MITCH1914's Avatar
Post
thanks guys i try to fix it first. if i have problems i will go with the push button
thanks again
Old 04-18-2002, 12:01 AM   #6
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Post
if the connectors are corroded and the wires are OK, a neat trick I learned is spray them with ether, that's right, ether. It will polish the brass in short order. WARNING!!!make sure the ether is dry before connecting and trying to engergize!!!!! If you decide to go with a push button, I'd make sure you get at least a 15 amp switch.
Ol' Buck: '72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84
ralleys and 31/10.5s
Angel girl: 67 Cutlass convertible
330, 3spd stick
Greener: 90 GMC Jimmy
350/auto
Chad Stephens
Orleans,NE
no name yet: 72 442 under serious construction
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
