Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > Review Board > Product Reviews
Old 07-22-2002, 08:40 PM   #1
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
Angry BEWARE of chrome Thermostate housings
Here are some picturs of a year old chrome thermostate housing it sprung a pin hole leak on Saturday and when I took it off the neck that the hose was clamped too was so thin my thumb made a hole in it .
Don't know what caused it ?
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 07-22-2002, 08:41 PM   #2
Bill72BB
Bill72BB's Avatar
Another shot of the neck.
BILL
Member DUF Club
Old 07-22-2002, 08:42 PM   #3
Bill72BB
Bill72BB's Avatar
And the inside
BILL
Member DUF Club
Old 07-22-2002, 08:45 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Wow..huge bummer, they will also cause corrosion on the alluminum intake. THe anti-freeze turns to battery acid frim the dis-simalar metals.
Chainge your coolant EVEY year.
Old 07-22-2002, 10:01 PM   #5
Bill72BB
Bill72BB's Avatar
Andy; What blew me away I've changed the coolant several time when I was experimenting with different Degree Thermostats.
I went back to a stock housing ,not taking any chances.
BILL
Member DUF Club
Old 07-22-2002, 10:08 PM   #6
Longhorn Man
I've heard of this hapening, and I have no idea what did it if you have flushed your system.
I know I check mine every 6 months or so when i chainge from coolant to water or vise-versa.
So far, so good.
Old 07-22-2002, 10:32 PM   #7
BubbaGreen
Anti-freeze for the most part will turn acidic over time, if your using the green stuff, change it every year. As far as the
chrome pieces go, most makers sacrafic quality for the shiny
look...knowing it will fail...thermostat housings, chrome pulleys...
etc, all fall into this catagory. What ever you decide to use, try
to select a metal that is the same as the intake, ie, if you run
an aluminum intake, get an aluminum t-stat housing. If you
have a stock cast iron, go scoutin the junk yards for an iron
t-stat housing, (most of them if even remotely protected from the
weather will still be usable) Good LUck.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 07-22-2002, 11:08 PM   #8
racedvl
racedvl's Avatar
I say beware of any chrome!! I am ainti chrome! I guess a air cleaner is ok, but that's about it.
racedvl is offline   Reply With Quote
Old 07-22-2002, 11:12 PM   #9
Super Chevy
Super Chevy's Avatar
Sucks to hear about that, i have one now and it seems to be ok,its the kind with the o-ring ,no gasket. PS nice camera
Super Chevy is offline   Reply With Quote
Old 07-23-2002, 01:02 AM   #10
Bill72BB
Bill72BB's Avatar
Super chevy ; sounds like the same one I had .
BILL
Member DUF Club
Old 07-23-2002, 01:08 AM   #11
junkyardjohn
junkyardjohn's Avatar
Question
IF YOUR WATER IS THE LEAST BIT ACIDIC OR HAS A HIGH MINERAL OR SULFER COUNT, ALWAYS USE DISTILLED WATER TO MIX WITH ANTI-FREEZE FOR YOUR COOLING SYSTEM. IT'S CHEAP & MAKES THAT GREEN STUFF (ANTI-FREEZE) LAST ALOT LONGER. IF YOU HAVE A DEHUMIDIFIRE IN YOUR HOUSE, ALL THE WATER THAT COMES OUT OF IT IS DISTILLED (OSMOSES??)
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 07-23-2002, 01:10 AM   #12
frost89434
frost89434's Avatar
I bought one of those once and when I went to put it on the bolt holes were off by about a half an inch
68 short fleet with 71 front clip 2wd jaguar blue
99 chevy ext cab shrtbed z71 loaded
99 chevy swb fleetside(daily driver)
Sparks, Nevada
frost89434 is offline   Reply With Quote
Old 07-23-2002, 01:14 AM   #13
TheMattMan
I dont even think the air cleaner should be chrome.......go adhead and spend the extra few bucks and get aluminum......Everything should be aluminum or stainless. Unless you are just building a old beater.........My bolts are even polished stainless with logo engravings.
TheMattMan is offline   Reply With Quote
Old 07-23-2002, 01:23 AM   #14
Hooter
My other Love
Hooter's Avatar
i had one of those chrome therm housings. damn thing corroded on me too. not maiking that mistake twice
MEMBER DISCS UP FRONT CLUB
  • 69 custom camper/cst 10
  • 70 monte carlo 383 stroker with a 700r4
  • 77 fully loaded silverado (back in the backyard for a little while longer)
  • 1980 BMW 320i (back in the garage finally)
  • 1981 f@*d f150 4x4 (Robert red ford) tried to kill me
  • 1972 Honda ct 90 trailbike
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com AC/DC RULES!!!
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 07-23-2002, 01:33 AM   #15
Sinister
Between Trucks...
Sinister's Avatar
that's bizarre...
i've been running a chrome one for a couple years with no problem, i'm using that orange long life prestone...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 07-23-2002, 02:15 AM   #16
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
ive heard of this happening to a bunch of diffrent people who run chrome thermo housings......... this looks like a good topic for the review board...... so im moving it there
68SWB4x4 is offline   Reply With Quote
Old 07-23-2002, 08:12 AM   #17
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
Go Billet.............JB
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 07-23-2002, 06:34 PM   #18
Longhorn Man
Well, my chrome one (with O-ring) has been in use since '98 when i bought the first Longhorn...no tellin how long it was on that truck before I got it. So far so good, and I really like the O-ring too.
On the one that the holes did not line up on, it was probably a pontiac one, thy look the same, but the holes don't quite match up. Pontiac and caddy have the same hole spacing too just in case any one was losing sleep with that question.
Old 08-13-2002, 10:10 PM   #19
1971LT1SWBPOSI373
1971LT1SWBPOSI373's Avatar
Same thing happened to me. Except my pin hole was located on the round part directly above the thermostat. I threw it out and bought a cast iron one from NAPA. Those things are junk, not worth risking your engine over.
1971 Shortbed 350/350 w/ Posi-traction 3:73's
1996 Chevy Silverado
TJ in Springfield, Virginia
Likes old Chevy trucks
Drinks Miller MGD
1971LT1SWBPOSI373 is offline   Reply With Quote
Old 08-14-2002, 10:55 AM   #20
Custom 68
Custom 68's Avatar
no problems here
I have had one with a temp sender hole on top for oh 10 years or so and no problems. Used to be my daily driver not as much now. Just pulled the engine and took that off still looks good?
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 09-03-2002, 05:41 PM   #21
COBALT
COBALT's Avatar
The chrome ones corrode, and the pot metal stock ones warp.
I finally went to Napa and got a cast iron one. Haven't had problems since, but the key is a good gasket and flat clean surfaces. Fel-Pro #35562T. It's a reusable gasket, and you don't use tack or gasket sealer to put it in. Just shove it in and tighen it down. Done.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 09-10-2002, 01:17 PM   #22
Nathan
If you can buy the part at O'Rielly's or Autozone in the "Dress Up" area, don't buy it. (Hell if it is from Autozone, don't buy it no matter what it is.) I've had problems with them not leaking, but when I go to flush the system and I change the hose, the damn neck on it will break off. I went back to the cast iron one.
Nathan
Vice President Texas Truck Association
Nathan is offline   Reply With Quote
Old 09-12-2002, 12:09 AM   #23
SoCal71K20
Count me in too.I used one before and it was crap.I think more
than type of coolant, is country of orgin of those damn chrome
pieces.I went to Napa to get a cast one with the little carb return
spring hole cast into it.Guess where it come from? Yeah,china too.
But yeah keep your green coolant fresh.I have heard too many
negative stories about the orange GM death-cool on a 90's
Suburban forum.I also flushed that stuff out and replaced it
with green coolant on my 98 Suburban.
SoCal71K20 is offline   Reply With Quote
Old 10-03-2002, 10:31 PM   #24
Crank
Crank's Avatar
What does it do to the aluminum intakes? Are the only thermo housings that corrode are made of Steel, metal, what? Yeah, what about billet specialties billet ones? Would they corrode? Are there any complaints about these? Nice bolts too, Themattman, where did you get hooked up with those, i've seen em before, did you get a whole set for your motor?
Brandon
Crank is offline   Reply With Quote
Old 10-20-2002, 12:33 AM   #25
GMC JUNKIE TOO
THE QUICKER FIXERUPER
GMC JUNKIE TOO's Avatar
I had a problem with chromed heater hose fittings the only ones i could find were chrome cost 11.99!!! got them home and one was steel and one not a few months it split all down one side found one for 2.99 and it works great.
GMC JUNKIE TOO is offline   Reply With Quote
