Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > Review Board > Product Reviews
Old 03-20-2006, 12:05 AM   #1
Skruffy
Skruffy's Avatar
Thumbs up Rokcrln's Tip & Flip dolly
I got my plans in the mail yesterday and am very happy with them. This looks like a great time-saver and can't wait to build one.
The plans were very complete and illustrated, not some crude drawing.
Skruffy is offline   Reply With Quote
Old 03-28-2006, 06:53 AM   #2
mbgmike
Smile Re: Rokcrln's Tip & Flip dolly
We used a computer 3d modeling system (SMART PLANT) and built each part component. This system is accurate to something like 1/128 of an inch Then we assembled the components per the drawings and instructions. It went together just like it should and looks like the photos. The only dimention we found that was off was the true length of the brace. It was so negligible that it didn't matter and actually would be a vent hole. We can rotate it into any view from any angle and now were going to build the real thing.
Mike
Mikes Bump and Grind Garage
mbgmike is offline   Reply With Quote
Old 03-29-2006, 09:36 AM   #3
Rokcrln
Rokcrln's Avatar
Thanks guys! I am open to any input anyone has.. Mike as far as that brace you mentioned yes it is the one variable item in the parts list. And in the directions it is stated to only worry about aligning one end! As far as the angel I figured most guys are using a chop saw for cutting and you know as well as I do trying to cut a 47.54321* is not real critical when your rod or wire will fill the small gap. Anyways guys I look forward to you using your Dollys!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 03-30-2006, 01:20 PM   #4
Karl Hoh
A little east of nowhere
Just reviewed the plans, I found the instructions and diagrams/pictures very easy to understand. I believe anyone with basic skills can build this. I can't wait to get started. Thanks Kevin, well done!!
68 C10 250 4spd
69 C20 327 4spd
69 910 250 3spd
80 K10 350 4spd
76 C60 366 5spd school bus
"THERE'S NOTHING YOU CAN BREAK THAT SOMEONE CAN'T BE PAID TO REPAIR"
Karl Hoh is offline   Reply With Quote
