Old 03-20-2006, 02:08 PM   #1
70c10
67-72 Addict!
70c10's Avatar
Van tilt levers and turn signal switch
I picked up a van tilt over the weekend for my dads 70' and and wanted to know if the TS arm and switch would work on this 81' van tilt?. Will his shifter arm work on the van tilt or does he have to buy all new parts from a 81'?. All his truck column stuff is brand new and I'm hoping he can reuse some of it. Thanks
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 03-20-2006, 03:44 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Van tilt levers and turn signal switch
The turn signal and tilt levers can be used
I don't THINK the turn signal can be used.
Shifter can not be used.
This is assuming that dad had a non tilt, and going to a van tilt...correct?
Old 03-20-2006, 04:16 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Andy- my dads truck column is a non-tilt but the switch and levers on his truck column are new. All three levers on the van tilt are nasty. So he can install his nice signal arm lever onto the new tilt ?. This means all he needs is a new shifter lever and switch??
Jim
Old 03-20-2006, 04:29 PM   #4
70GMCer
70GMCer's Avatar
Jim, it has to be a tilt shifter arm. I may have an extra arm up here and you're welcome to it. The switch should work. I used the good one out of my 3spd column. Went right in.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 03-20-2006, 11:59 PM   #5
70c10
67-72 Addict!
70c10's Avatar
Thanks Steve. I'll check it out next weekend.
Jim
Old 03-21-2006, 07:56 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You can make a tilt lever out of an old turn signal lever by hacksawing it to length and threading the end with a 1/4-20 die. It will screw right in.
Old 03-21-2006, 12:31 PM   #7
70c10
67-72 Addict!
70c10's Avatar
Thanks for the tip TX Firefighter.
Jim
