Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 03-25-2006, 03:06 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
stereo instalation
i bought and tried to install a radio yesterday and it work. i am replacing an existing cd player and im not really starting form scratch. i match each color wire together and connected all the connections. what would be some frequent mistakes i could have made? the radio doesnt even light up when i turn the key.
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 03-25-2006, 08:33 PM   #2
55ChevyPU
55ChevyPU's Avatar
Re: stereo instalation
bad fuse, bad hot, or bad ground. Or the radio is busted.
55ChevyPU is offline   Reply With Quote
Old 03-25-2006, 08:54 PM   #3
crm318
crm318's Avatar
how would i test the hot wire? could i put a tester on it? if the ground is bad, could i make a new ground on the body or any metal surface (im really bad at electronics).
1972 Cheyenne
Old 03-25-2006, 10:14 PM   #4
randomhero472
randomhero472's Avatar
i used a factory ground clamp behind the gauge cluster on the right side, where the existing ground was for some electrical. Put a test light/volt meter on your contstant hot and your switch hot.. if you have good voltage its your ground, if not its your 2 hot wires... hope that helps
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 03-25-2006, 10:24 PM   #5
matthufham
you need the power wire to go to constant power even with the key off you need power for that, that way you can use the memory function (save your radio presets). thats usually a yellow wire. then run the red power wire to the fuse panel in the stock radio location. that gives functioning power on accessory and run. i grounded mine to the dash speaker bracket on the firewall directly behind the head-unit.
matthufham is offline   Reply With Quote
