Old 07-26-2002, 11:44 AM   #1
johnnyp
Keepin' It Stock
johnnyp's Avatar
Windshield trim question-repost
I'm posting this over here for Smitty62 - he posted it on the Paint and Body board but didn't get any replies
I need to remove the windshield to fix some rust and a leak and to repaint the dash. Before I start, what's the best way to remove the stainless trim? The gasket on there is a new one--I guess I'll probably ruin it getting the windshield out--right?
72 Sierra Grande - Maych
Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
johnnyp is offline   Reply With Quote
Old 07-26-2002, 01:52 PM   #2
JimKshortstep4x4
Smile
This would be my suggestion. If the windshield is good, have it taken out by a professional. The seal, trim and window should come out as a unit. Done carefully, the seal, trim and windshield will not be hurt. In my area the shop that I use charges $30 to remove the windshield with or without the chrome, (installation is $60). I would advise against doing it yourself. (Back glass is relatively easy to do yourself, but the windshield can be a problem).
Jim
Old 07-26-2002, 10:07 PM   #3
chevy71super
Agree, you don't want to try to take the trim out without taking the windshield out. You will ruin it. The trim and the rubber must come out together. Have someone take the windshield our for you. May save the cost of the windshield unless you know what you are doing. (Just don't forget your goggles for the trip home!)
chevy71super is offline   Reply With Quote
Old 07-28-2002, 06:58 AM   #4
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
These guys are probably right but wanted to mention that I did manage to remove the chrome from a truck in the junk yard with the glass in. You must go very slow so you don't kink the trim. I was sweating it out! LOL
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 07-28-2002, 08:07 AM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
The other issue is rust. You must have some doubts about the condition of the metal under the seal. The only way to know, AND to fix it, is to remove the windshield and the seal, to access the area where I would be willing to bet that you'll find some rust...the amount not known.
In addition to the ravages of time, some people seem to think that using RTV as a sealer is a good thing. There are different kinds of RTV, but those which contain acetic acid will cause rust. If anyone ever used that type of sealant, you'll have that to contend with, too.
As much trouble as it may seem to be, and if I read your post correctly, you are wanting to get rid of the rust around your windshield. So, in my opinion, you have two choices...remove it and do it properly, or, the other way.
Member Nr. 2770
