Old 08-01-2002, 10:27 PM   #1
mt Al
HELP!! AC/Heater cables placement / size
This is driving me crazy!!
I'm putting in new AC/Heater cables in the suburban. It only had one cable in it when I got it (the one from the temp slide that goes into the engine compartment) and I haven't had an AC cab for over 14 years and can't remember which of the other two goes where and hooks up to what.
I have three cable lengths from good old GMC Paul. I assume that I need to hook up the two shorter ones from one of the top two slides to either the metal heat/defrost box on the hump and the other to the heat/AC hose diverter (and the AC compressor switch on the back).
Can some kind soul tell me which cable goes to which slide that hooks to which box?
Thanks. My wife and children also thank you.
'72 GMC 1/2T 4x4 1500 Super Custom pickup (current)
past rides were:
'70 Chev 2wd farm truck
'71 GMC 2wd 1/2T 402 nice!
'72 Chev 2wd 1/2T 396
'72 GMC 3/4T 4x4 2500 Super Custom suburban.
Bozeman, Montana
mt Al is offline   Reply With Quote
Old 08-01-2002, 10:42 PM   #2
RodC
RodC's Avatar
Not sure if what you need is there, but I have all the diagrams from the Chassis manual on my webshots site. Address is in my signature....
Rod Childers
'71 C10 Stepside
RodC is offline   Reply With Quote
Old 08-01-2002, 11:35 PM   #3
billogna
billogna's Avatar
You probably know by now, but I'll post anyway. The top slider goes to the closest box by your feet to switch between the defroster vents and bottom vents. The middle slider goes to the center box with the a/c switch, and has the shortest cable.
'69 Chev Cust/10 swb, 350/700R4, 5"/6"
'70 Chev C10 swb, 67 front, 454/700r4, 4"/5"
'73 Chev stepper, 350/3 spd
'84 Chev K20 350/4 spd
'91 GMC 1500 Suburban 4x4, 350/700R4
billogna is offline   Reply With Quote
Old 08-02-2002, 11:23 AM   #4
mt Al
Thanks much. Both of you helped a lot. The diagrams from the book are great! Now I know what all that vacuum crud is trying to do.
I'll be re-A/Ced by tonight (God willing).
Thanks again, this board is great.
past rides were:
Bozeman, Montana
