Old 06-11-2006, 05:40 PM   #1
dwcsr
Hollister Road Co.
dwcsr's Avatar
hydroboost
Does anyone know what the fitting sizes are on a 2001 1/2 ton GM hydroboost.
And what type of fitting is used ie.. oring at end of fitting or IV flare type.
I need to make some custom hoses and it will need the fittings. I don't have the original hose to look at.
What I'm doing is putting it on my 58. I have a 2001 silverado 1500 4 wheel disc hydroboost and master cylinder. The auto parts places here say the hoses are not available.
Thanks,
dwcsr is offline   Reply With Quote
Old 06-12-2006, 10:17 PM   #2
BigDan3131
BigDan3131's Avatar
Re: hydroboost
Try www.abspowerbrake.com they do alot of one off setups like yours.
BigDan3131 is offline   Reply With Quote
Old 06-14-2006, 06:52 PM   #3
Re: hydroboost
You can have custom hydraulic hoses made all over.
Old 06-14-2006, 07:28 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: hydroboost
I know I can have them made but they all ask what size fitting do I want. I went to the junk yard and looked at one and the ends are o-ring type and those fittings are meteric only as far as I could find. One side is M18x1.5 and the other is m16x1.5 so I ordered one each and we'll see if they fit.
Old 06-14-2006, 10:43 PM   #5
Shane
Shane's Avatar
Re: hydroboost
May be showing my ignorance here, but what is a hydroboost and how does it work?
Shane is offline   Reply With Quote
Old 06-14-2006, 11:08 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: hydroboost
its a brake booster that runs off the power steering pump. its great for low vacuum engines. At idle I have about 12 inches of vacuum so I wouldn't have much in the way of brakes in traffic or low speeds. Its that black cast iron unit behind the master cylinder.
Old 06-15-2006, 11:02 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: hydroboost
Originally Posted by dwcsr
its a brake booster that runs off the power steering pump.i....
Shane, these are OEM on most trucks larger than a 1/2 ton.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-15-2006, 01:50 PM   #8
Shane
Shane's Avatar
Re: hydroboost
Gotcha ... thanks guys!
Old 06-21-2006, 11:45 PM   #9
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: hydroboost
just for reference the fittings are M18x1.5 with an O ring at the bottom and M16x1.5 with an o ring at the bottom
Old 10-12-2006, 02:28 PM   #10
Inthuwind
Straight jacket required
Inthuwind's Avatar
Re: hydroboost
TTT ~just to be clear, what year and size trucks can I get from the yard to do this swap into my '68 stepper???
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 10-12-2006, 04:07 PM   #11
Bad Karma
Magnificent bastard
Bad Karma's Avatar
Re: hydroboost
Summit is selling hydroboost conversions now, not sure how much more expensive they are compared to the salvage yard...
1977 Big Block Burb
Bad Karma is offline   Reply With Quote
Old 10-12-2006, 04:56 PM   #12
qksilver
Re: hydroboost
quite a few different GM models had them. Astro vans, anything diesel, and of course trucks.
Mike, I will call you this week end.
Steve
qksilver is offline   Reply With Quote
Old 10-12-2006, 10:42 PM   #13
Inthuwind
Inthuwind's Avatar
Re: hydroboost
Ok Steve, give me a call. I'll be at the Toby Keith concert in Raleigh Sat. night if you can call me before 2pm, or call me Sunday. I'm really interested in the hydroboost setup. I remember you telling me about the 3/4 ton pickups and diesels, just needed some years to look for.
