06-20-2006, 10:53 PM | #1 |
crossmember from brake pully
HI YOU GUYS
I'M NEW TO THIS, SO PLEASE BEAR WITH ME I HAVE A 1964 GMC PU IT WAS A STICK NOW I PUT AN 327 IN IT, THAT AN AUTOMATIC, HERE MY PROBLEM THE TRANMISSION MOUNT IS BEARLY TOUCHING THE CROSSMEMBER WITH ALL THE PULLY AND BRAKE LINE, DOES ANYONE KNOW IF THERE ANOTHER TRANMISSION MOUNT OR A E-Z WAY TO MOUNT THE TRANMISSION TO THE EXISTING CROSSMEMBER WITHOUT MOVING THE CROSSMEMBER ALSO HOW ABOUT THE STEERING COLUMN I WANT TO TAKE OUT THE STOCK ONE AND PUT IN A TILT AND IDEA WHAT MAKE AND MODEL OF CAR OR TRUCK I CAN SWAP THIS FROM? YOUR HELP IS GREATLY APPREICATED |
06-20-2006, 11:25 PM | #2 |
Designated A-hole!
Re: crossmember from brake pully
Welcome to the board from South Mississippi! I don't know about '64's but on the 67-72 trucks there's a different crossmember for automatic trannies.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
06-21-2006, 02:24 AM | #3 |
Gone Fishing
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
06-21-2006, 08:23 AM | #4 |
Happy to be here
Welcome to the forum gilbert. I moved your post to the 60-66 forum hoping you might find an answer to your problem. Good Luck...
06-22-2006, 08:38 AM | #5 |
you need a 63-72 auto crossmember,, 73-87 will work but look different, brian
06-22-2006, 08:58 AM | #6 | |
Iron Thunder
from Phoenix Arizona. |
06-24-2006, 06:14 PM | #7 |
C10 now is a GMC
Welcome to the board Gilbert.
If the truck originally had a manual trans, you will need to cut out the crossmember that originally under the bellhousing. Then pick up a trans crossmember from any automatic truck from '63-'72, and bolt it up where you need it, an dshould be ready to go. You might have to drill a few holes for the new crossmember. I had to do this on my truck. As for the stering column, you can get one from a mid 70's Chevy/GMC full size van, these do not have an ignition key on the column, that way you can still use the original ignition switch in the dash. The main brace that holds it to the dash will need a some adjusting, but any newer column will need this. But since it being a GMC, the wiring harness's are different from a Chevy wiring harness. Jolly's webpage should have wiring diagrams for the dash wiring for when wiring in the new steering column. Make sure which ever steering column you end up choosing, amke sure that you get BOTH male & female connectors so it will be easier when wiring. David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod *1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser *1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project |
