Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 06-25-2006, 01:14 AM   #1
roger0080
Is the Stock AM Radio interchanagable with the stock AM/FM Radio ?
I have a stock AM radio in my K20 and recently purchased a stock AM/FM radio. Can I use the same wiring harness and connectors on both radios ?
Also, does anyone have any suggestions or links to a good replacement speaker for the stock speaker up in the dash? I thought I saw years back where someone had a stereo speaker replacement for the same location as the original one. I would still like to use the same location. Don't want to cut, nor use kick panel speakers. Thanks.
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
Old 06-25-2006, 05:29 AM   #2
JimKshortstep4x4
Talking Re: Is the Stock AM Radio interchanagable with the stock AM/FM Radio ?
The AM harness can be used on the AM/FM radio as the plug is the same configuration.
GMC Paul has the dual speaker setup that bolts into the stock location. Here is a link:
http://www.gmcpauls.com/stereo_equipment1.htm
Jm
Old 06-25-2006, 01:10 PM   #3
nyncompute
nyncompute's Avatar
This guy has a replacement 10 ohm speaker for Delco radios but I'm not sure if its a direct bolt in. I've delt with the guy before ..he does good work
http://www.turnswitch.com/speakers.htm
nyncompute is offline   Reply With Quote
Old 09-08-2006, 06:50 PM   #4
roger0080
I ended up using the 4x10" Delco Special (speaker mounted to plastic base) from www.turnswitch.com
No problems with the installation.
I picked itup in person since they are local in Minneaplis.
Friendly and great guy to deal/work with.
I can crank the AM/FM all the way up and at about 98% volume level, maybe, some distortion, but that's too loud.
Thanks for the link.
-Roger
Old 09-09-2006, 06:45 AM   #5
There`s no point in using two dinky speakers in place of one larger/better sounding one.Like the AM,the AM/FM is not stereo.
