Old 08-05-2002, 04:26 PM   #1
JHickson6
I Love This Stuff!
JHickson6's Avatar
Question Help, How do I remove my guages?
I'm in the process of tearing apart my truck and I am stuck trying to tke the guages out. I removed all of the screws around the perimeter on the guage panel. How do I get the choke, wiper, and light knobs off? what else is holding the guages onto the dash?
Thank You Guys!!
JHickson6
My Rides
1967 C10 In Pieces for now
1985 Ford B700 SourPuss Bus - BIG BLUE
2003 Silverado CITY WORKER YELLOW!!
JHickson6 is offline   Reply With Quote
Old 08-05-2002, 04:29 PM   #2
Zkast
Zkast's Avatar
You'll need to take a small screw driver or pick and pull back on the tab (just at the base of the knob's) then remove the 2 retaining nuts for the choke/headlight switch.
If you have a small mirror you can pull the headlight switch on and look behind the knob, you will see a tab sticking out around the base of the knob.
Zkast is offline   Reply With Quote
Old 08-05-2002, 05:54 PM   #3
greasemonkey
greasemonkey's Avatar
The wiper knob has a set screw. Unscrew it with a small screwdriver, loosen it so you can pull the knob off. For the lights, pull it out to parklights, reach up behind, push the tab down and pull out. I had the same problem a few weeks ago.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 08-05-2002, 06:24 PM   #4
JHickson6
I Love This Stuff!
JHickson6's Avatar
thanks guys i got them and the most of my dash!!!
I took two bolts out of both sides of my dash and it still doesn't come out, it it welded in?
JHickson6
My Rides
Old 08-05-2002, 06:26 PM   #5
DARK OLIVE 72CHEYENNE
DARK OLIVE 72CHEYENNE's Avatar
GAUGES
AFTER YOU GET THE NOBS YOU WILLNEED TO TAKE THE OIL PRESSURE LINE OFF AND THE SPEED OMETER LINE THEN THE HOLE THING SOULD COME OFF
DARK OLIVE 72CHEYENNE is offline   Reply With Quote
Old 08-05-2002, 06:30 PM   #6
Zkast
Zkast's Avatar
OH! your taking the whole dash out?? I believe these are pinch welded to the cab and make up part of the windshield sealing surface.
Old 08-05-2002, 07:06 PM   #7
woodrow59
OzarkHillbilly in Atlanta
Yeap .... if you're talkin whole dash , that's a new ballgame.
Good Luck !!!!
72 custom/10 LWB
68 Longhorn C20 Custom Camper (sold)
woodrow59 is offline   Reply With Quote
Old 08-05-2002, 09:28 PM   #8
JHickson6
I Love This Stuff!
JHickson6's Avatar
Thanks again guys, it's all done!!
JHickson6
My Rides
