Old 08-06-2002, 07:03 AM   #1
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Portable Carports
My Burb is about 6 inces too long for my new garage So I went looking for one of the portable ones y'know with the poles and canvas/aluminum. I checked Sears, Home Depo, Only one I found, is with just a top cover, it had no sides, and I want as much protection for my truck as possble. Any suggestions?? This is a rental house so I cant "attach" or "build" anything to it, (knocking out the wall already crossed my mind) Thanks in advance !!!!!!
"The unexamined life is not worth living" -Socrates
'71 GMC Suburban 4x4
GMCjunkie is offline   Reply With Quote
Old 08-06-2002, 08:58 AM   #2
Jeff M.
Jeff M.'s Avatar
Hi there Jodie! My brother bought one of those for his extended cab pickup. Used it a few years and the tarp gave it up. So he went and bought some corrugated metal at Home Depot and drilled and bolted that to the frame. He extended it down the sides to about 3' from the bottom. He also extended the length by 2' in the front and back. Turned out looking surprisingly good. He had to add a small piece of metal to the ends to keep the metal from flapping in the wind. All in all, not a bad carport for the money spent.
69 C-10 CST Short Fleet, Factory Air, BB427-400 Auto-2400 stall-tilt-cruise-Tach & Vac Gagues, 4/6 drop, power one piece side windows, Eaton posi.
Jeff M. is offline   Reply With Quote
Old 08-06-2002, 09:29 AM   #3
68 Suburban
68 Suburban's Avatar
Jodie, get a Hemmings Motor News. I know they have a bunch advertised in there. How is the A/C working?
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 08-06-2002, 09:55 AM   #4
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
I recently bought a "portable" style carport. One of the $595.00 ones that you see for sale up here in Va. The guys that put it up rolled. They were in and gone in an hour and a half tops. They are some good quality carports that can easily be enclosed. I'm sure that they probably have them near you too. I upgraded and got the taller one for more roof clearance. Hopefully, I am planning on building a garage in summer 2004, I can put this behind it, enclose it and use it for a spray booth...................JB
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 08-06-2002, 11:43 AM   #5
StingRay
StingRay's Avatar
Try Costco. I've seen them there lots of times. Watch out with those portable carports though as the wind can get them real easy and beat the h&ll out of your truck in the process. I've watched the wind get two of the larger ones and blow them around. It wasn't pretty.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 08-06-2002, 11:55 AM   #6
Bamm
Bamm's Avatar
My carport was put in the ground with 4- 6ft long ground rod type anchors. You can even add some more if you want. I'm not saying that they will stop a hurricane or anything like that, but we have had some heavy winds since I got mine and I haven't had a single problem.............JB
3/4 Drop 350/700R4
Tilt wheel
My Zip is 23002
I ship UPS, USPS
Old 08-06-2002, 12:05 PM   #7
Mudder
Mudder's Avatar
695 here
For ones with a hard roof and I have seen ppl add sides to them. You do have to anchor them down good though.
Mudder is offline   Reply With Quote
Old 08-06-2002, 12:16 PM   #8
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I did a search for "Carport" on MSN...
http://www.domeshelter.com/
http://www.economytent.com/html/carports.htm
http://www.patiostore.com/hi1.htm
http://www.tuffshed.com/
http://www.yourfencestore.com/canopy.htm
http://www.screen-house.com/?source=overture
http://try-tech.com/
and then there is the good old stand-by, JCWhittney
http://www.jcwhitney.com/product.jhtml?CATID=123213
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 08-07-2002, 07:24 AM   #9
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Thanks guys!!! I appreciate all the info!! Lots to choose from, never knew there were so many.
68 Burb, The a/c works fine, a little too much condensation on the inside of my truck for my liking, and mabey Im too much of a perfectionist, but I think they could have been a little "neater" with the install, under the hood wise, just seems like they randomly bolted stuff in there. The unit itself works great, but Id NEVER recommend the Beavis and Butthead team that installed it. Modesto Auto Air on McHenery ave, Modesto Ca.
Ill try to get some pics of it all and post them, The way I look at it, its better than not having air at all.,
Thanks again!!!!
