08-06-2002, 06:59 PM | #1 | |
Bloo
need answer quick
im trying to start my truck, sinse i moved the shifter (3 in the floor, wouldnt let me hook up the speedo cable, so i moved the bracket back) got a speedo now
but what i need to know, is it ok to start the truck with the battery charger hooked to it? i have over the normal amount of voltage (two regulators) so im afraid ill blow up the charger or my battery
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
08-06-2002, 07:04 PM | #2 |
Hmmm... I've never worried about it. It's never done anything bad when I've done it.
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
08-06-2002, 07:14 PM | #3 |
Some battery chargers have a start position you can shift it to so you don't burn out the charger. It provides a boost of current for starting the engine by providing enough juice to the starter motor. Usually the charger has an amplifier in it that if it gets too hot it simply clicks off.
Why do you need to start it with the charger connected?
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
08-06-2002, 07:52 PM | #4 | |
Bloo
i was wanting to start it with the charger hooked up, because its one of those little chargers that only have a 2 and 6 amp position (lil cheap ones) and it takes toooo long for it to charghe the battery so i was goign to let the altenator do it
