07-27-2006, 11:26 AM | #1 |
1968 re-do underneath.need help
I have a 1968 Chevy Stepside 1/2ton. Almost everything is done on the body but i NEED new shocks and springs badly. I am new to everything trucks/cars so i need some advice.
I want shocks,springs,and whatever i need to make it ride like a "caddy" or close. But i want to lower it a good 4" or 5". So where should i order from and what type? should i get...if there are specific ones for old trucks or something...im clueless
'68 Chevy 1/2ton Longbed |
07-27-2006, 01:44 PM | #2 |
Hollister Road Co.
Re: 1968 re-do underneath.need help
You may want to go with an air ride kit. Because you don't have much experince I would go with the Air ride technologies kit. They have very good support and you won't have to piece together a kit. I would also ask them about the drop for the rear. Some 2.5" drop spindle for the front.
Early classics also has some good kits. They also have a section which shows what the kit looks like on your truck when installed. http://www.earlyclassic.com/Tech.asp...=Stance+Photos Some may reccomend ***************** for the parts but you would have to piece together and weldup a lot of parts to get it to work. I don't find them that much cheaper after shipping is added in. what you want is not cheap. |
07-27-2006, 04:25 PM | #3 |
Thanks man, that helped me get in the right direction. I think the 4/6 drop looks the best and i would love to get that. But wow..like you said it will cost some moula!$$$$
However. what are the advantages of an AIR RIDE KIT to regular suspension? they seem to be about the same price. Also, any certain brands i should either leans towards or stay away from? also, Am i correct in thinkine the AIR RIDE KITS will allow me to adjust the height on the fly...like a lowrider type thing. And how low can air ride kits go?
07-27-2006, 06:06 PM | #4 | |
Outlandish Trends - FL
If you're not concerned with going to the ground, add in a c-notch ($100), super track bar, shocks, shock relocators, and you're set. I think that's everything.
-Bret 67 short-fleet sold! |
07-27-2006, 11:08 PM | #5 | |
Hollister Road Co.
The bad is you have to drain the water out of the fill tanks periodically and there are more parts to have a potential problem. I happen to like Air Rid Technologies kits. They are a little more but like I said they have very good support if you run into something that doesn't work right and their kits fit. Two words of advice number 1. with any kit you get is that you check the parts list first to make sure all the parts are there prior to ripping down your ride. The second is don't shop by price alone. This is one area that you really do get what you pay for. Call them up before you buy and if they don't or can't answer your questions before the sale they won't after. I guess thats three word of advice. |
07-28-2006, 12:52 AM | #6 |
Epoxy Primer Friendly
"The only thing he'll have to weld in with the kit from S.D. is the lower cups to the a-arms."
This isnt true. You dont have to weld anything in the SD kit for the front. |
07-28-2006, 11:24 AM | #7 | |
Seņor Member
Edit: Oops... Note to self: Read whole thread before replying. camaro__thunder already got this one.
07-28-2006, 07:08 PM | #8 |
oh really? Sweet!! Even less work for me to do tomorrow!
07-28-2006, 08:06 PM | #9 |
Hollister Road Co.
Does the rear on this year have trailing arms or leaf?
07-28-2006, 09:59 PM | #10 | |
Happy to be here
07-29-2006, 10:48 AM | #11 | |
I have 1 leaf frame & 1 coil frame sitting in the driveway so it's better to look & see what's under there.
