Old 04-22-2002, 07:33 PM   #1
Pumkin Truck
Thats just prime!
Pumkin Truck's Avatar
Post how do i measure the stroke
Through the spark pluggs right? i have been told to use a coat hanger as the easiest way. But as to how, just stick it in and measure the depth? Dont eat me alive with this one! thanks
*69 GMC short bed stepside with a wimpy six that can barely pull itself.
*99 Chevrolet Camaro Z-28
1 Bad 5.7ltr LS1
Pumkin Truck is offline   Reply With Quote
Old 04-22-2002, 07:37 PM   #2
69 longhorn
Post
The only sure way that i know ,is to pull a head,& roll a piston to bottom center,then measure from the top of the piston to the top of the deck. then subtract .030-.035 for factory deck clearance.........69
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-22-2002, 09:08 PM   #3
Jesse 67 c-10
Jesse 67 c-10's Avatar
Post
Are you trying to figure what motor it is? If you have the displacement I'm sure someone here can rattle off all the specs on it. I belive a 327 is 3.25 and a 350 is 3.4 something, thats all I know
Jesse
Near Saskatoon, Saskatchewan, Canada. 67 c-10, Long fleet, Newly swapped front disks, 5 lug rear end, 327 v-8 with Vortech heads, edlbrock performer rpm air gap manifold, 1406 carb and comp XE 256 cam. Backed by a getrag 5 speed and 1 piece driveshaft. Finnally running, almost driving! www.geocities.com/chevy67jesse
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft.
1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power.
Jesse 67 c-10 is offline   Reply With Quote
Old 04-22-2002, 09:11 PM   #4
69 longhorn
Post
A 350 is a 3.48 stroke......but Im not thinkin! You can run the # on the eng to find what it is.......69
Old 04-22-2002, 09:49 PM   #5
Pumkin Truck
Thats just prime!
Post
to tell the truth, the engine is a cad i know for sure, but the person who i got it from was not sure to what year or model he got it out of. the 472 and 500 have the same eternal dimensions and have been told the only difference is the stroke, so i am crossing my fingers hoping it is a 500, i couldnt find the block numbers so i am gonna try and atempt to do it the hard way, but i dont know how
1969 Gmc swb stepside Wimpy six soon to be a 500cid cadillac!!
1 Bad 5.7ltr LS1
