Old 04-22-2002, 08:18 PM   #1
Project1970
14.1 @ 96MPH
Project1970's Avatar
Post Plugs for an HEI setup?
I figure if I'm going to pull the plugs on my engine, I'll go ahead and replace them, they're cheap enough. It's just a more-or-less stock 1970 350, original in the truck...I believe the standard plugs with .035 gap are ACDelco R43's? Do they make that plug with a .050 gap instead? (because I'm just lazy like that and if the cost is no different, why not... =)
Project 1970 - soon to be seen at http://milhouse.treylis.org:81/
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 04-22-2002, 08:39 PM   #2
704x4
Post
plugs aren't gapped from the factory
70 3/4 ton 4x4
FOR SALE
Greene, IA
704x4 is offline   Reply With Quote
Old 04-22-2002, 08:44 PM   #3
69 longhorn
Post
If you are running the washer seat plugs,I think it was a 45 that I used(its been a while). At any rate, use the plug that the truck calls for,& open the gap to .045 & you should be ok........69
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-22-2002, 09:22 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
I wouldn't go to .050...that is a good way to burn up plug wires and coils.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-22-2002, 10:08 PM   #5
Chumley
Post
The AC Delco plugs with the "X" after the number refers to extra wide gap. FYI, "T" designates tapered, and "S" extended tip. Hope this helps you, Chumley
Chumley is offline   Reply With Quote
Old 04-22-2002, 10:14 PM   #6
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Post
I'm using ac r45t plugs with .045 gap on mine.
Ol' Buck: '72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84
ralleys and 31/10.5s
Angel girl: 67 Cutlass convertible
330, 3spd stick
Greener: 90 GMC Jimmy
350/auto
Chad Stephens
Orleans,NE
no name yet: 72 442 under serious construction
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
