09-05-2006, 10:27 PM | #1 |
Dash Radio Speakers
I have some speaker questions: First, does anyone have a source for the OEM mono 10 ohm speakers? Second, I have seen that the dual cone stereo dash speakers come in different versions for Chevy and GMC. What gives, I thought they were all the same? Also, some of the aftermarket stereo speakers are for A/C, some are not.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
09-06-2006, 09:44 AM | #2 |
Junior Member
Re: Dash Radio Speakers
I just bought a dual cone speaker because I could not find the original and I figured that by the time I rigged something up, I would have as much money into it as buying new. In the listing, there was only 1 part number, nothing about Chevy/GMC air or not. It came from Southern Ky Truck parts for $40.00. I put it in with the stock radio and it sounds okay for a 40 year old AM radio. It fit well but I had to modify my stock harness to plug it in because it just came with connectors on the speaker end.
09-06-2006, 09:48 AM | #3 |
theres a clearance problem with the center vent thats why the AC one is different
a true pain in the ass to install by the way
09-06-2006, 04:02 PM | #4 |
If you want a stock speaker disregard this, but forget the dual cone unless you have very damaged hearing anyway they sound terrible. Your best bet is to find a pair of good sounding small speakers that will fit in there and make up a bracket to mount them.
P.S. the easiest way to work in there is to pull the glove box.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
09-06-2006, 07:53 PM | #5 |
I am a Referee of life.
If you want a stock type replacement speaker you can usually find one at Radio Shack.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
09-06-2006, 10:08 PM | #6 |
Thanks for the information. I found a place that can 're-cone' my original speaker, and I am going to see what they want for doing that. The thing is those original speakers were 10 ohms, and many of the speakers made today are less. They do not sound good with an original radio (I have an original AM/FM).
09-06-2006, 10:26 PM | #7 |
What your looking for is on this site. http://www.turnswitch.com/speakers.htm
I ordered the 4x10 delco special from this site. It uses the original bracket and is the correct 8 ohm speaker for our trucks original radios. I put one in my truck and the sound is excellant and it has more room than the original. These are great guys to deal with and I highly recommend them. Just an FYI but acording to my radio tech you must use an 8 ohm speaker if you are using the original radio or you will damage the radio. Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
09-06-2006, 11:34 PM | #8 |
Thanks for that link! You and your radio tech. are right, those older Delco radios must have an 8-10 ohm speaker.
09-07-2006, 11:28 AM | #9 |
Perfect timing , i was going to post a similar question . I just bought an orig am/fm . This site rocks .
Later ............................................ 409 .
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
09-07-2006, 01:52 PM | #10 | |
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
