Old 09-06-2006, 01:51 PM   #1
grebus1
grebus1's Avatar
Upgrading Burb for towing
I'm looking for some suggestions on upgrading my Burb for towing. It is a stock C/10 402/400 with no towing provisions. I'd like to be comfortable towing a small trailer or boat less than 7000 lbs. (if that's possible for a 1/2 ton). I like the ECE hidden hitch setup, but am unsure what else to add (air bags, etc.). Thanks in advance...
'72 Chevy Suburban Custom Deluxe 10, 402/TH400
grebus1 is offline   Reply With Quote
Old 09-06-2006, 08:51 PM   #2
oldiron
Designated Grumpy Old Man
oldiron's Avatar
Re: Upgrading Burb for towing
A good transmission cooler, also depends on the tongue weight if you need any supension help. It would be cheaper to use a easy lift hitch then air bags if needed.
oldiron is offline   Reply With Quote
Old 09-07-2006, 12:31 PM   #3
70rs/ss
70rs/ss's Avatar
It is possible to use the 3/4 ton rear springs to replace the 1/2 tonners on the burb to help with the squat, and then an equalizer hitch is the way to go, I lost a trailer and burb off of a tounge hitch and wish I had used the above mentioned hitch instead.
70rs/ss is offline   Reply With Quote
Old 09-07-2006, 09:01 PM   #4
qksilver
Plus , as per my experience, others will disagree, is that the coil springs feel looser towing and sway more than the leaf spring style. Coils will give you a better ride though.
Just make sure everything is rated for at leat 25% MORE than you think you will tow because it almost always ends up that what you are towing weighs more than what was thought.
Make sure you have a trans cooler, rated tires that are properly inflated, safety chains, trailer brakes on at least one axle, well tuned engine and remember most of all driving smoothly, turning, stopping, starting ,looking ahead are really important
qksilver is offline   Reply With Quote
Old 09-07-2006, 10:41 PM   #5
Frizzle Fry
Frizzle Fry's Avatar
I was just thinking about sway. Didn't some factory tow packages include a rear sway bar? I know they did on later models. This may be something to consider adding as well.
Frizzle Fry is offline   Reply With Quote
Old 09-14-2006, 08:08 AM   #6
jku72
If you are upgrading, upgrade to polygraphite bushings, and end the sway. That, and a set of 3/4 ton springs. Forget about converting to leaf springs.
Also, run proper tires with at least a D load range, and inflated properly.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 10-10-2006, 09:59 AM   #7
98L150
///Relaxed Atmosphere
98L150's Avatar
I added a tranny cooler to my 350/700R4 combo and pull in drive. Works fine for me, could use a little bigger radiator as it gets a little warmer going up and down hills, but no other problems. I set the air ride were I want it and the trailer I pull has a load equalizer hitch to transfer the load off of the tongue. Here is a pick from just this past weeked.
Jeff
72 Suburban
64 Chevy short fleet
04 Chevy Colorado Sport Reg Cab
2012 Chevy Avalanche
2003 Chevy S10 Blazer Xtreme
http://www.hubgarage.com/mygarage/RA_Jeff
64 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=295915
98L150 is offline   Reply With Quote
Old 10-10-2006, 12:14 PM   #8
71SWBChevy
Post Whore
71SWBChevy's Avatar
Sorry to ask a stupid question but what in the world is a load equilizer hitch? Never heard of one before. I am sure I have seen one just maybe by another name or something like that.
Drew
'71 Chevy 350/TH350 Hugger Orange
Currently just a rolling frame, body work soon to follow!!!
Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927
Daily Driver: 1997 Chevrolet S-10 with more gears than pistons
71SWBChevy is offline   Reply With Quote
Old 10-10-2006, 01:44 PM   #9
98L150
98L150's Avatar
here is a web site that has a good diagram and pics explaining what it is and how it works.
http://www.hitches-forless.com/WD/about_wd_hitches.htm
72 Suburban
64 Build Thread
Old 10-10-2006, 03:26 PM   #10
70rs/ss
70rs/ss's Avatar
D@mn it, I wish I had followed my own advise, the sway is what caused my 68 4X4 original Suburban to become a rollover before I ever even got to drive it!! The hitch levels the ride and prevents sway, and with coils as qksilver mentioed is a feeling that you get from coils. Use the hitch, you'll never regret it, as I always say (especially after my accident!) load for bear even when hunting for squirrel, and you'll never be suprised!!
Old 10-10-2006, 04:04 PM   #11
qksilver
It also helps to have a 3/4 BB burb...........!
Old 10-10-2006, 06:22 PM   #12
71SWBChevy
Post Whore
71SWBChevy's Avatar
Cool thanks man! I have seen those hitches before but I never knew that is what they were for!
Drew
Old 10-11-2006, 06:40 PM   #13
68gmcdually
68gmcdually's Avatar
I even use the big hitch on my leaf sprung dually. Works amazing!! You can certainly tell the difference from when you are using it and when you aren't.
James Bellwood
1968 930 Extend-A-Cab Dually 5.7l, 5 speed,
68gmcdually is offline   Reply With Quote
Old 10-11-2006, 07:42 PM   #14
72freak
Rottenwood Garage Member
72freak's Avatar
1) trans cooler..a must!!!!!!!!!!
2) Brake controler/trailer brakes
3) steering stabilizer
4) a good rear bag system or heavy duty rear springs
5) tow mirrors, spot mirrors or clip on mirror extenders
6) class 3 or higher hitch
7) a variety of different drop recievers
8) good tires
9) power steering
72freak is offline   Reply With Quote
Old 10-12-2006, 10:37 AM   #15
MrGoodpliers
MrGoodpliers's Avatar
Dang, Jeff, that burb looks just as good aired up!
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
