10-22-2006, 07:27 PM | #1 |
Air Ride Compressor ?
My 68 has been on hiatus for a while now. I've been piecing the front suspension back together lately & this weekend I actually sat it back on the ground & off the jackstands.
I'm using a manual fill system w/no solenoids so it's just the air-tank, comp, lines & gauges. I wanted to adjust the rear of the truck to my typical ride height (30~35psi air) but when I went to add some air to the rear bags they just deflated even more instead of adding air. The batt is out of the truck so I tried using jumper cables from my 74 over to the 12v lead that went to the comp but it doesn't work. The fuses are good & I re-checked the ground. For whatever reason, the comp won't kick on to supply air to the tank. I wound up yanking the discharge line from the compressor & installed a schrader valve to manually fill the air tank from my home compressor. Once the air tank had pressure, I was able to add air to the rear bags w/o issue. The comp worked w/o any issues earlier this year. What's stopping it from coming on now? What would be more likely: bad pressure switch or bad compressor?
10-22-2006, 07:38 PM | #2 |
A guy with a truck
Re: Air Ride Compressor ?
Bypassing the pressure switch will answer that. Try removing and bench testing the compressor and go from there.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
10-22-2006, 08:46 PM | #3 | |
I couldn't verify the output @ the jumper cable end because I left my 'start-up'/engine electronics toolbox over @ my buddies place the other night when we fired up his new 355. I'll bring it home one night this week & see if I have a bad connection w/my voltmeter. Is there any other way to check the compressor?
10-22-2006, 11:30 PM | #4 |
what kind of compressor is it?
10-22-2006, 11:36 PM | #5 |
Standard ART opening price-point stuff: Thompson 315. It's been on the truck for 4yrs now (3 in use, 1 sitting in the driveway).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-22-2006 at 11:39 PM. |
10-23-2006, 11:19 PM | #6 |
Happy to be here
This don't sound good. If you were getting any voltage at all it should try to turn over. Sounds like it may have died on you...
10-24-2006, 12:18 AM | #7 |
Yep....That's my guess. I'll know for sure after getting my voltmeter & 12v test light back home.
