10-22-2006, 09:35 PM | #1 |
Sectioned x-member 1 3/8"
Got my x-member sectioned 1 3/8" now just need to paint and install.
If you can't rock the roads with your bumpers 1/2" off the ground, you're nowhere near low enough! |
10-22-2006, 10:17 PM | #2 |
Re: Sectioned x-member 1 3/8"
Nice job, not an easy task.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
10-22-2006, 11:16 PM | #3 |
I highly recommend installing the crossmember & test fitting all the steering pieces before painting anything.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-22-2006 at 11:16 PM. |
10-23-2006, 01:27 AM | #4 |
i don't see there being a problem with fitment or clearance issues. This x-member was sectioned an 1 3/8" to avoid such problems. I have a buddy who has done a few of these now so it should just pop right in. I have already takin care of the steering linkage. Either way, if i have to do a lil grinding here or there, its nothing a lil paint won't cover up later. This one's just going on my winter beater anyway.
10-23-2006, 07:39 AM | #5 | |
Even after cutting the u-bolt, it still would not clear. I had to shim the c.member down 1/4" to get clearance. Now it will turn lock to lock w/o hitting but it is pretty close (1/8"~1/4"max). If I do another one, I won't go more than 1 1/8".
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-23-2006 at 07:41 AM. |
