Old 10-25-2006, 01:55 AM   #1
solidaxel
solidaxel's Avatar
Anybody using Flat Out Engineering
Has anybody finished a AD 1/2 ton and used a Flat Out Engineering crossmember or C4 Corvette suspension IFS. ???
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 11-10-2006, 01:33 AM   #2
fuchster
fuchster's Avatar
Re: Anybody using Flat Out Engineering
Hello:
I am using Flatout's installation kit. I recently finished installing all the C4 components. The donor car was an 1985.
Flatout made simpler but it is still lots of work. I am now in the process of installing the motor and tranny.
Are you using Flatout's parts? Do you have any pictures of your project?
Let me know if I can help you with anything,
Raul
My project is at http://www.cardomain.com/ride/2330005
fuchster is offline   Reply With Quote
Old 11-10-2006, 02:26 AM   #3
solidaxel
solidaxel's Avatar
Damn, I just typed a 4 paragraph question answer and I guess I was not logged in!!!!!!!!!!!!!!!!!!!!!
LS 3 4L70E
Old 11-10-2006, 05:56 PM   #4
fuchster
fuchster's Avatar
Nice truck!
Are you using the Flatout parts?
I can not tell from the pictures.....
How about motor mounts and tranny crossmember?
Later..
Old 11-10-2006, 08:23 PM   #5
CAL 58 GMC
CAL 58 GMC's Avatar
Nice looking truck!!
CAL 58 GMC is offline   Reply With Quote
Old 11-11-2006, 12:26 AM   #6
solidaxel
solidaxel's Avatar
No, I am building another 53 Chevy and I am researching IFS kits and I looked at Flat Out parts and just wondering about how they stacked up with Mll parts. Maybe someone will respond with some real life miles on a Flat Out parts!
I am thinking that the geometry of there kits vs. Heits or TCI or some of the other folks out there should be the same ??? if all the kits used the same coilover shocks!!
The crossmember for the front end is home made with Mll stock parts and chevy big brakes with the most important part BILSTINE shocks. No rear crossmember as I am running a cast bellhousing with a Tremec TKO 600 5 speed. Motor mounts were fabed from 2" strap with stock rubber mounts. I had the Mll parts on the truck for 15 yrs before everything wore out and started leaking which prompted a total rebuild of the truck
and now I have over 8000 fun filled miles and smiles!!!
LS 3 4L70E
Old 01-15-2011, 09:07 PM   #7
duwem
duwem's Avatar
Anyone using their rear kit?
Progressive it telling me I need to step in the truck frame to fit the vette suspension since the truck frame is too wide.
Flat Out's kit fits right on with no frame mods.
Dont get it???
duwem is offline   Reply With Quote
Old 01-16-2011, 04:00 AM   #8
Deabt54
Deabt54's Avatar
Dont get it???
I know what you mean duwem, I'm using progressives front kit. I wanted to use their rear set but it cost more that I wanted to spend. And flat out wouls have the frame higher than I wanted. So I'm notching the frame so to speak. Did this today.
Deabt54 is offline   Reply With Quote
