Hi,
I have a 1972 chevy pick up...love the truck..it is used as a farm truck....sometimes I don't use it for months at a time...last week it ran fine, now it will not go into drive...it goes in reverse fine, but when I drop it down to drive it just sits there like I have it in netural...I am hoping it is not the transmission...I checked the transmission fluid, it is fine...any possibilities as to what it is????? Dan Dickerson otuck@watervalley.net |
Designated Grumpy Old Man
![]() Join Date: Oct 2001
Re: 1972 Chevy pickup question
I'm moving this over to the Pickup forum for you.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
it may be in the linkage you should have someone look under it while you try to shift it .(with your parking brake on)
sufficiently talented fool
![]() Join Date: Jun 2006
It is possible one of the valves in the trans is sticking. I have had luck with Sea-Foam trans additive. It is available here at Federated Auto Parts. Just add it to your trans and start the truck. Let it run for a bit and then try it. If need be, try moving it in reverse some and see if it doesnt break free. May or may not work, but worth the $7.00 to try. Good Luck!!
Bob
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
P.S.
Welcome to the board!!!
I agree with centless. If it was fine when parked most likelly it has the gear selector valve might be sticking. Like mentioned before try some kind of additive. Marvel mystery oil is another good one to try.
Designated A-hole!
Welcome to the board to both the new members.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
