Old 11-11-2006, 10:12 PM   #1
Lagg
engine problem on an 82 with 350
when i drive down the road ad get to about 30-35 the engine will cut out and will even die if i dont let off the gas but i can sit in park and rev it up all the way and hold it and it runs fine any ideas on this is it as easy as a fuel pump or as difficult as a transmission? or does anyone know the exact part? is it possible that it could be something on the 700R4 trannie?
Lagg is offline   Reply With Quote
Old 11-11-2006, 10:24 PM   #2
lilpup69chevy
67-72 parts finder
lilpup69chevy's Avatar
Re: engine problem on an 82 with 350
a manual fuel pump isn't expensive or hard to put on i don't know why the transmission would cause it to die, sounds like a fuel issue maybe the filter on the carb is dirty? try cleaning or replacing it and the fuel pump, since its a carbureted engine its something simple
1969 chevy shortstep 2wd (under construction)
1981 chevy scottsdale lwb 2wd (parts chaser)
2004 pontiac gto (daily driver)
2004 pontiac grand prix gt (the ol ladys car)
1985 chevy short wide
1970 chevy c10 lwb (another parts rig)
1969 gmc lwb (rainy day project)
1968 chevy lwb c10 250 I6 3 spd (soon to be swb)
lilpup69chevy is offline   Reply With Quote
Old 11-11-2006, 10:32 PM   #3
magnethead
7000 #'s of american IRON
magnethead's Avatar
check your lockup electronics and TV cable
magnethead is offline   Reply With Quote
Old 11-12-2006, 01:24 AM   #4
Lagg
lilpupchevy ive changed the filter havnt done a pump yet though i know i can do it myself for like 9$ but would it be the pump if i can sit there and rev it up fine in park or neutral
magnethead what/where is the lockup electronics? as well as the tv cable ive heard that term before just not ringing a bell though
im new to chevys i got this one in a trade trying to get it running right then ima do all the restoration work im normally a ford man but im giving chevy a chance and i got a good setup drivetrain wise if i just get it working properly to impress myself with a chevy
Old 11-12-2006, 01:59 AM   #5
Lagg
well i just traded a set of 6x9 speakers for a quadrajet carb ima put that on it and see what it does if it does the same thing ill just give my old carb to my cousin lol he needs one for his 86 custom anyway and also if it dont work ill post again on here
Old 11-12-2006, 02:09 AM   #6
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Kinda sounds like fuel pump but does not at the same time. Cause it will die and not start and run crappy at random times. But not good alot and then some bad.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 11-14-2006, 01:56 PM   #7
bigpig72CST
I had the exact same problem with an 85 K5 I used to have. Surprisingly, it was a cracked distributor cap. It would sit and idle and even rev up fine, but driving it was the same issue you are having.
bigpig72CST is offline   Reply With Quote
Old 11-15-2006, 12:27 AM   #8
Lagg
thanks ill check it thursday when im off might buy one just to put on it i work at O'reills so i get discount anyway
Old 11-17-2006, 12:30 AM   #9
Lagg
well it did need a new cap and rotor but that wasnt the problem it still does it anyone else got any suggestions? im bout to pull the carb off and put this other one on its only doing it when the secondary butterfly opens so it could be the secondary jets in the carb?
Old 11-17-2006, 05:41 AM   #10
73stepside
73stepside's Avatar
sounds like the problem is the carb isn't jetted properly on the secondary side or it has all kinds of gunk clogging the passages on the inside
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
Old 11-17-2006, 12:22 PM   #11
Lagg
thats what ima do next is change the carb ive already got one to put on it so no biggie now ill change it in the next few days then ill get back to yall on the progress on whether it works or not
Old 11-17-2006, 12:46 PM   #12
piecesparts
Parts and more parts
piecesparts's Avatar
What does this beast have for a carb? Is the carb a "Qaudrajet" built by Rochester of Carter. If it is the Rochester Quadrajet, then you are OK, but if the Quad is a "Carter" built unit, then there is a design problem inside where the secondary needles feed through the lower bowl. The Rochester unit has brass inserts around these needles and the metered flow is maintained without problem. The Carter design does not have the brass inserts and the bowl erodes away around the needles and the carb will tend flood and bog out the motor when you accelerate. This cannot be fixed, short of a toss into the junk pile and a Rochester body used in it's place.
piecesparts is offline   Reply With Quote
Old 11-17-2006, 05:43 PM   #13
magnethead
magnethead's Avatar
*scribbles in notepad*
