Old 12-05-2006, 02:42 AM   #1
edmonton72
Nothings as cool as my 72
edmonton72's Avatar
Van Tilt Column Questions
I have found a local ad for a GM Van tilt column. What kind of modifications would have to be done to fit this into my 72. Is the wiring plug the same? If it has a shifter what would I have to do to remove it because i am going with a B&M floor shifter. And finally what's the difference between these columns then then stock truck and aftermarket ones.
1972 C10 Longbox
In the middle of body off restoration
Rebuilt 355, turbo 400, 3.42 12-bolt
Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding.
edmonton72 is offline   Reply With Quote
Old 12-05-2006, 08:05 AM   #2
Southedisto
River life......
Southedisto's Avatar
Re: Van Tilt Column Questions
The part number for the adapter is 1894851 you GM dealer can get them, less than 10$. Someone on the board may have one to sell.
Here is the link that I used to mod mine.
http://www.67-72chevytrucks.com/vboa...=modified+tilt
Southedisto is offline   Reply With Quote
Old 12-05-2006, 08:12 AM   #3
neonlarry
neonlarry's Avatar
And this:
http://67-72chevytrucks.com/vboard/s...threadid=63328
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 12-05-2006, 09:40 AM   #4
Huck
Huck's Avatar
The van tilt needs to be a late 60's to early/mid 70's without the keylock on the column. The Van units are longer then the truck columns so the lower shaft will need to be shortened. The Van unit has the neutral safety switch located where the column come close to the pedal mount so it would have to be removed---you could rewire this to the floor shifter with some creative tweeking. You can get flat connector to curved connector from GM. Modifying the column for floor shift would require either cutting and smoothing the upper cover (shifter, indicator, pointer holder) or replacing this with the floor shift pieces (you'll never find them!!). Alternative is an aftermarket column from Ididit which will set you back around $400.
I would do the Van thing and keep it simple/cheap. Just be sure to position the steering wheel to allow for thanksgiving dinner impacts! hehehehe
Huck is offline   Reply With Quote
Old 12-05-2006, 06:13 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if it is an early van unit, there will be 2 locations for the neutral safety switch... but you aren't going to need it anyways, just remove it and forget about it. (Hooking the NSS on your floor shifter is on you... if you go to a track that goes by NHRA rules, you'll get kicked out without it) The early van units have the 1/2 moon turn signal switch plug too.
How much are they asking for this column if I may ask... They aren't really worth a WHOLE LOT unless redone and real nice.
Old 12-05-2006, 11:10 PM   #6
edmonton72
edmonton72's Avatar
The column is from an 82. I haven't phoned the guy yet so I don't know what kind of shape it is in. He's asking $140 cnd. for whuch is around $120 usd. I'm still wondering if I should go with this column or an ididit or flaming river column.
1972 C10 Longbox
Old 12-06-2006, 01:30 AM   #7
Longhorn Man
there were only a hand full of 82's without the ignition switch... make sure this is one of them. The *normal* 82 column will be a bit of a PITA to install.
120 isn't too bad if it is decent to nice.
