Old 12-24-2006, 01:31 PM   #1
1969k10stepside
Question Blazer driveshaft same as truck driveshaft?
I am buying some parts for my swb 4x4 from a wrecked Blazer and the guy is selling a new front driveshft for the blazer also.My question is...is the front driveshaft from a Blazer the same as a driveshaft for a 71 swb 4x4?If someone would be so kind and measure the length of one I can see if its the same as the one for my truck.
Thanks and Happy Holidays,
Dustin
1969k10stepside is offline   Reply With Quote
Old 12-24-2006, 02:12 PM   #2
desertrat
desertrat's Avatar
Re: Blazer driveshaft same as truck driveshaft?
Because my Blazer is lifted I had my front driveshaft lengthened. So I probably wont be any help.
desertrat is offline   Reply With Quote
Old 12-24-2006, 02:22 PM   #3
1969k10stepside
Good thing you mentioned the lift kit because I forgot to take the 4 " lift into consideration I dont think I will need a longer front driveshaft for just a 4 inch lift though.I didnt have to on 79 although a Blazer could be different.
Old 12-24-2006, 04:00 PM   #4
Critter
Future TOTM Winner
Critter's Avatar
From what I have learned, the front drive shaft and axel is the same from truck to blazer. They will interchange, assuming that the transfer cases are the same from one to the other. With a 4-inch lift, I don’t think you have to make any modifications. You would have to with a 6-inch. Sorry, I can’t give you an exact length at the moment.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 12-24-2006, 04:24 PM   #5
1969k10stepside
Well,I have until Thursday before I go to pick up the transmission,transfer case,and some other stuff.That should be enough time to get a answer so I know whether it will work or not.
Old 12-24-2006, 05:11 PM   #6
desertrat
desertrat's Avatar
What does youre blazer have in it or going to have in it? I currantly have dana 44 front end, small block chevy mounted in the back position, turbo 350 trans, 205 transfercase with a 4 inch lift. I beleive all of this plays a factor in drive line length, if you have the same setup I can measure mine for you.
Old 12-24-2006, 05:39 PM   #7
1969k10stepside
Truck will have 350/th350/np205 in it with a 4 inch lift.Dana 44 front axle.Wrecked blazer has dana 44,350 sbc/th350/np205.Stock height
Old 12-24-2006, 06:18 PM   #8
desertrat
desertrat's Avatar
My drive line is 25" from center of u-joint to center of u-joint at ride height. I have everything you will have.When drive line is fully pushed in at the slip yoke it should be about 23".
I can't tell you what the stock drive line is (should be about same) but I had my driveline made for my blazer.
Old 12-24-2006, 09:55 PM   #9
Troy-Built
The parts you are getting from me were from a Blazer with a 4 inch lift and the front driveshaft is the same length as my other truck I am working on with an automatic.
69 Chevelle SS 375/396 TKO 600
71 Suburban 3/4 4x4 402 5-speed (project)
68 chevy C10 shortbed 327 5-speed (project)
72 Blazer 4x4 400 4-speed (wifes project)
Numerous 67-72 parts trucks
Troy-Built is offline   Reply With Quote
Old 12-25-2006, 12:37 AM   #10
1969k10stepside
Good to know.Now I just need to know if I need a new front driveshaft anyway.
Old 12-25-2006, 12:00 PM   #11
jcfoote60
Active Member
jcfoote60's Avatar
They are the same, just did this yesterday! swapped out my 72 SWB CV driveshaft with a STD u-joint one from a 72 blazer. same length overall.
jcfoote60 is offline   Reply With Quote
Old 12-25-2006, 12:22 PM   #12
lilpup69chevy
67-72 parts finder
lilpup69chevy's Avatar
well the front end is the same from a blazer to a truck only difference is wheelbase which is not cut out of the front so a front driveshaft will interchange
1969 chevy shortstep 2wd (under construction)
1981 chevy scottsdale lwb 2wd (parts chaser)
2004 pontiac gto (daily driver)
2004 pontiac grand prix gt (the ol ladys car)
1985 chevy short wide
1970 chevy c10 lwb (another parts rig)
1969 gmc lwb (rainy day project)
1968 chevy lwb c10 250 I6 3 spd (soon to be swb)
lilpup69chevy is offline   Reply With Quote
Old 12-26-2006, 01:53 PM   #13
1969k10stepside
Found the driveshaft that came with the truck.Dont look like I am getting that driveshaft anyway.
Thanks for the replies
