![]() Join Date: Nov 2006
audio help... now what
When my brother asked what I wanted for xmas the other week, I mentioned that I was eyeing a pair of cheap speakers to slap in as part of the interior restoration. Anything's an upgrade over the single mono deal right? Well, the man presented me with a quality pair of 6.5" 500 watt speakers this afternoon and I've been trying to figure out all evening what to do with them.
My original plan was to buy a new head unit, a pair of cheap speakers and walk away. But now that I'm presented with the chance for real sound, I don't know where to start. I'm pretty sure I need an amplifier now, right? If anyone has an idea of a good (cheap) way for me to get these in and sounding they way they should, please help. Mounting is not an issue, I can figure that out. I just need to know what head unit and amplifier (if needed) to go with. Thanks.
79 C10 Silverado |
Re: audio help... now what
You could go with an amp. Go ahead and get a decent head unit, you can get a "decent" one for around $150...
As for amp, don't go and get a high end 500 watt amp. Those speakers will not handle it... True 500 watt 6.5 speakers are few and far between, and uber expensive. Try running them off a head unit that has 25-50 watt per/chan output and see how they sound for you. From there, you can decide if you want to blow some $ on an amp. |
7000 #'s of american IRON
post a model number and manufacturer. pictures might help.
I got a dual shaft cheap 2x25/4x15 kenwood cassette player in mine and it gets plenty loud with cheap 6.75" jensens in front and lightning's in back. |
Well, You could buy an amp, but the pickup is so small, as well as the speakers so you might just get too much sound for that small of a cab. I would suggest getting a deck that pushes at least 100 RMS watts per channel. That would be plenty of sound for a pickup cab. Really full loud sound comes from a combination of larger speakers and air movement. Two things that are really hard to get in a pickup cab.
If you are going to get an amp, I would recommend a Rockford Fosgate unit, from 200 to 500 watts. They always rate their products in true RMS, so you don't get a "1000" watt amp thats really just 500. Be aware, that you get exactly what you pay for, so a 1000 watt amp for $50 isn't a quality sound, just a loud one. Whatever you do, good luck! P.S. I've seen 2 10's underneath a 65 chev seat, so anything is possible. |
Thanks all that's a great help,
That would be great if I could get away with nothing more than a decent head unit, so I'm going to give that a try, once I decide where to mount them, that is. There was one other question I forgot to ask. Assuming I buy a head unit with a clock in it, am I going to be able to provide power to keep the clock running off the existing radio wiring, or do I have to pull some other "always on" hot wire for that? Thanks again.
79 C10 Silverado |
get a crutchfield install guide. It's 5 or 10 bucks, unless you happen to have a manual that ident's each individual wire in the stock harness.
on aftermarket units, red is the always on wire, yellow is ignition trigger. |
#7 | |
Thanks again!
79 C10 Silverado |
![]() Join Date: Oct 2006
Good advice on taking a look at RMS power. That is the average output that you can expect from a head unit. I would also assume that the 500 watts is the 'peak' for your speakers. Some manufacturers will give that listing if their product can handle 500 watts for 1/100th of a second. Not a good indicator of what the speakers can do. I would hesitate to get an amp, I have a nice pair of 6x9s in my truck with an average head unit, and they are more than enough.
On my Sony the yellow was constant +12v and the red was ignition +12v.
'85 Chevy 383/700R4/205 |
