Old 01-09-2007, 11:37 PM   #1
pissonNOS
senior member
pissonNOS's Avatar
air bag question you might think im stupid
I'm wonder if itd be an alright idea or make sense to install airbags using just the stock spindles? am I going to get much lower than I already and with a 3" drop from cut coils out back im not too worried i can just weld in a notch but up front i dont really want to buy drop soindles right now should i do it ? or would i be better off to save my money for spindles then go bags?
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 01-10-2007, 12:11 AM   #2
smoked68
smoked68's Avatar
Re: air bag question you might think im stupid
id prob go with drop spindles first...wish I had done that to begin with b/c im getting ready to buy some now. you will thank yourself in the long run.
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 01-10-2007, 12:35 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Do it right, and do it once...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-10-2007, 12:01 PM   #4
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
I bagged mine first without spindles, then got spindle late on. ALot of people do it. If I had the money I would've done it all at the same time.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 01-10-2007, 12:53 PM   #5
jimmydean
jimmydean's Avatar
You can do it in phases, but you will end up doing a lot of work. You will need to pull just about everything off and it's easier to do it once.
I damaged the lower ball joints when I pulled everything apart, so I ended up replacing all the ball joints. If you can do it without damage, then you might be ok.
It's still a lot of work you will have to do all over again.
jimmydean is offline   Reply With Quote
Old 01-10-2007, 02:21 PM   #6
pharcyde05
pharcyde05's Avatar
i have my bags in and still have the stock spindles it willget quite a bit lower than with 3 in springs i would do the bags first cause you might be as low as you want to go and there might not be a need for the spindles
if you want to get lower you know what you have to do then
pharcyde05 is offline   Reply With Quote
Old 01-10-2007, 11:33 PM   #7
pissonNOS
senior member
pissonNOS's Avatar
all very valid points guys thank you, pharcyde05 have you run into any problem runnig with the stock spindles and also have any pics of how low it is?
69 GMC bagged
Old 01-11-2007, 01:10 PM   #8
pharcyde05
pharcyde05's Avatar
hear are some pics but i also have a 2.5 in Zed frame
i had to get longer brake lines all the way layed out they were streched tight
Old 01-14-2007, 02:07 PM   #9
sittininttown
sittininttown's Avatar
ive got a 79 bagged and i lay rockers with stock spindles. now i do have my frame "z" ed 4 inches and i boxed the frame in under the cab to get it to lay but it can be done.
build it, bag it, bodydrop it, the low life, the only way to live!
sittininttown is offline   Reply With Quote
