01-11-2007, 12:21 AM | #1 | |||
Union Electrician
Let's see some pics of shaved firewalls
I would like to see omse shaved firewalls, and also looking to know what to shave and why and what you did to make it as clean as you can.
TIA Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
01-11-2007, 02:08 AM | #2 |
Re: Let's see some pics of shaved firewalls
I also would like to know. I am going to be attempting mine probably next week!
Josh
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
01-11-2007, 08:18 AM | #3 |
Here are a few pics of a curent customer build I am working on. Check out "project lemon drop" for more pics.
Kevin LFD Inc. |
01-11-2007, 10:24 AM | #4 |
thats awesome work. looks very good!!
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
01-11-2007, 10:53 AM | #5 | |||
Union Electrician
Thanks Kevin,
I'm glad you posted that pic, I wanted to ask you about the rail you shaved off just below the ccowl, won't that let water rund down the firewal more since it doesn't have any where to go now, or am I
01-11-2007, 12:09 PM | #6 |
Looks sweet Rokcrln! So what are you going to do with all the wires and stuff like the fuse block, speedometer wire, winshield wipers, ebrake and so on. I would love to do something very similiar to that. Thanks
Josh
01-11-2007, 12:42 PM | #7 |
http://www.cardomain.com/ride/2461088 |
01-11-2007, 12:44 PM | #8 |
Both of these are great work.
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
01-11-2007, 02:15 PM | #9 |
i like the yellow one b/c it all smooth it doesn't have the other humps in it.
69 4wd V6 20k orig miles!! 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
01-11-2007, 03:29 PM | #10 |
Here's mine.
My Suburban Project 72 Suburban 68 SWB 57 Belair 55 Cameo 06 Chevy 1/2 ton crew 09 Suburban |
01-11-2007, 03:37 PM | #11 |
hey gregfull what color orange is that ??
01-11-2007, 05:56 PM | #12 |
It's a 2005 Nissan 350Z color.
01-11-2007, 09:50 PM | #13 |
Gregfull, 'Just LOVE that color! Gorgeous. Nice project pics too.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
01-11-2007, 10:49 PM | #14 |
i,am gonna do that to my firewall. they only rust i have on my whole truck is in the heater air intake across the front of the firewall and i was perplexed as how to fix it. after seeing how nice these firewalls look its going to be how i do mine except i want factory air . that lip removed across the top looks killer. chevy should have done that......
bob in tn. |
01-11-2007, 10:52 PM | #15 |
when you remove the stock wireing harness fuse block what do you use in place of it ?
01-12-2007, 12:44 AM | #16 |
That looks alot like the color ppg made for project copperhead.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
01-12-2007, 12:49 AM | #17 |
Commander Taco Bello
for those of you with the shaved firewall, are you not running a heater?
i thought about removing mine because it will be parked for the winter, and i don't have AC, so there's really no need for a heater. |
01-12-2007, 01:17 AM | #18 | |||
Union Electrician
I will be using an aftermarket heat& A/C, only thing you will see is the bulk head where the four fittings will be for the hoses.
01-12-2007, 01:28 AM | #19 |
On project Lomon Drop he has Heat and A/C and an 18 circut Painless harness and you will see none of it when finished!
Kevin LFD inc. |
01-12-2007, 01:30 AM | #20 |
so where are the heater core lines going? is there a kit for this?
01-12-2007, 01:48 AM | #21 |
01-12-2007, 01:57 AM | #22 |
01-12-2007, 02:01 AM | #23 |
So where did you put the new fuse block?
01-12-2007, 02:24 AM | #24 |
i put it in the same spot under the dash, i just had the cut the whole in the firewall a little bigger.
i will post some pics soon! Last edited by cstm68; 01-12-2007 at 02:27 AM. Reason: miss understood the question |
01-12-2007, 03:31 AM | #25 |
That is one nice looking orange truck
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
