Old 01-13-2007, 09:25 PM   #1
boomer
Are they drop spindles????
http://i117.photobucket.com/albums/o...t/IMG_0701.jpg
Can you guys tell if im using A DROP SPINDLE with these pictures. Dont wanna z it 4 inches if im runnin a stock spindle when i could go to a 2 or 2.5 inch z? Im that low in the front probably due to running no cups and just lettin the bag sit in the lower control arm bolted underneath.
http://i117.photobucket.com/albums/o...t/IMG_0700.jpg
http://i117.photobucket.com/albums/o...t/IMG_0695.jpg
http://i117.photobucket.com/albums/o...t/IMG_0691.jpg
http://i117.photobucket.com/albums/o...t/IMG_0690.jpg
http://i117.photobucket.com/albums/o...t/IMG_0689.jpg
boomer is offline   Reply With Quote
Old 01-13-2007, 10:11 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Are they drop spindles????
Definitely a drop spindle... looks like it is a Belltech?
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-13-2007, 10:12 PM   #3
boomer
I snuck in behind the tire and I measured from beside the bottom bolt on the back with the diaper pin in it and measured up to the center of the spindle and its about 3/3/8's of an inch. It says GM-T AND UNDER THAT IT SAYS L obviously for left. So im dealing with a stock spindle. Right. Id say the gm gives it away.lol
Just wanna make sure cause ill z it still but with a smaller z if i get 3 inch drop spindles on there ill need a 2.5 rather than a 4 inch Z. Runnin 26.0 diameter tire.
Old 01-13-2007, 11:32 PM   #4
jimmydean
jimmydean's Avatar
Yes, that is for sure a drop spindle. Notice in this picture where you can see the back of the spindle is about 2 inches above the lower ball joint. If it was a stock spindle, it would be at the bottom.
jimmydean is offline   Reply With Quote
Old 01-13-2007, 11:42 PM   #5
boomer
fair enuff but what does the initials GM-T MEAN ON BOTH Spindles.
Im not disagreeing im just baffled what the gm means?????
There is no belltech written anywhere or djm just that gm-t..
Old 01-14-2007, 12:37 AM   #6
boomer
It really sucks if they are drop spindles cause im gonna have no choice whatsoever but to zd this stupid thing 4 inches. Thats how far the bottom of the frame rails are from laying out when the truck is bagged out. Seems to me though that lots are doing 3 to 4 inch z's. A little more mods with A 4 inch compared to a 2.5 i suppose. And im only running a 26.0 inch diameter tire too. I thought if they werent drop spindles that would be why my frame rails are so high off the ground and sounds like they are so seems to me everyone who has a 73-87 who trims the bottoms off the frame and airs out there bagged chev is 4" inches off the ground before the z. Guess math tells me that before i trimmed the 2 inches off the bottom i would have been 2 inches closer than i am now.
Old 01-14-2007, 12:49 AM   #7
jimmydean
jimmydean's Avatar
My guess is the GM stamped on the spindle is so you know it's for a GM, not a Ford. Some sort of an identifier like FD for Ford, or TY for Toyota or something.
What bags are you using and how are they mounted? Do you have a lower cup that you can trim so the bag sits deeper in the pocket?
Old 01-14-2007, 01:02 AM   #8
boomer
my bags are slam specialties and they are mounted to sit right in the lower control arm with no cups. There is a plate on the top. I.F customs does alot of that kind of placement for the bags, not the best way for them but hey.
If its a drop spindle i see that you said they put it on there as an identifier but i cant see that happeneing. Like would belltech put gm on there spindles if there shipping a spindle to a gm truck. Or would djm put ford on there spindle if its going on a ford truck..
It has gm written in 2 spots on the back and then a serial number as well.
Old 01-14-2007, 01:08 AM   #9
PBFAB.COM
PBFAB.COM's Avatar
It IS a drop spindle... the GM markings have to be an identifier the manufacturer of the spindle uses... GM is NOT the manufacturer of that spindle.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-14-2007, 01:26 AM   #10
Shane
Shane's Avatar
dude, it's a drop spindle ... listen to what these folks are telling ya
Shane is offline   Reply With Quote
Old 01-14-2007, 01:52 AM   #11
boomer
alritee a 4 inch z it is. Thanks .
Old 01-14-2007, 01:58 AM   #12
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
BTW, here's what stock spindles look like:
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 01-14-2007, 05:35 PM   #13
boomer
Right on guys. Thanks for the input and pictures. It did the trick. Appreciate it.
Old 01-17-2007, 12:53 AM   #14
milehightoyz
AttentionDeficitDisorder
milehightoyz's Avatar
by the way, i think you have yourself a pair of drop spindles.
milehightoyz is offline   Reply With Quote
