Old 01-18-2007, 02:30 PM   #1
69face
69face's Avatar
Little Brothers 74 Build Up!
I started building a truck for my little brother(he's 12) for his 12th birthday and i haven't posted anypics so here are some. sorry for being so tardy in posting. Name:  74hunter 004.jpg
Name:  74 Frame 001.jpg
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness!
my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal:
I'M SO SO CAL!
69face is offline   Reply With Quote
Old 01-18-2007, 02:35 PM   #2
69face
69face's Avatar
Re: Little Brothers 74 Build Up!
more picsName:  74eng 014.jpg
I'M SO SO CAL!
Old 01-18-2007, 02:41 PM   #3
69face
69face's Avatar
I'M SO SO CAL!
Old 01-18-2007, 02:47 PM   #4
69face
69face's Avatar
I'M SO SO CAL!
Old 01-18-2007, 07:28 PM   #5
84 400
Sb 400 club
84 400's Avatar
WOWO nice project!!! i love the pic of the bed in the back of the elkiy!
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 01-18-2007, 11:18 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Holy crap. He's 12...?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-19-2007, 12:15 AM   #7
69face
69face's Avatar
I'M SO SO CAL!
Old 01-19-2007, 12:22 AM   #8
69face
69face's Avatar
I'M SO SO CAL!
Old 01-19-2007, 12:30 AM   #9
69face
69face's Avatar
I'M SO SO CAL!
Old 01-19-2007, 12:39 AM   #10
69face
69face's Avatar
yeah, i want to make sure he gets as much action in high school as possible. lol!
I'M SO SO CAL!
Old 01-19-2007, 05:41 AM   #11
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Thumbs up Re: Little Brothers 74 Build Up!
Nice project there but i'm confused on why you did that frame repair it looked like it was fine to me. Was it bent or cracking or something?
Just one sugestion i'd strip that TPI back to bare aluminum and clear it theres just too much black in that Eng. compartment.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 01-19-2007, 11:26 AM   #12
69face
69face's Avatar
No it wasn't bent or cracking it was just a bit hideous. i want a person that knows absolutely nothing about cars or trucks to be able to look at these pics and not be grossed out by the snot welds the previous owner put on the frame. I'm trying to make it look like night when you open the hood that's why so much black.
I'M SO SO CAL!
Old 01-19-2007, 12:32 PM   #13
Russell
Professional Grade
Russell's Avatar
One suggestion for future frame repairs, make the cut about half way down the frame rail on the front, then go back 5" and cut half way up from the bottom, then cut straight down the center from the front cut to the rear cut, then grind the edges down a bit to make a bevelled edge.
Then when you weld, you'll have a far stronger joint than if you weld straight down the frame like you did. The reason has to do with the way steel becomes brittle when you heat it way up like that, thereby hardening it. By welding it across the center of the rail like like I suggest, it has a greater area to dissipate heat, so no specific spot gets quite as hot. I'd also have reccommened fish plating the inside of the frame rail to add some more strength, esspecially on the frame rail with the steering box.
Too late now, but keep a close eye on that joint and watch for signs of cracking!
Otherwise, lookin' real good!
Tell us a bit more about the engine you've built -- What kind of heads are those? Camshaft specs? Compression ratio? Speed Density or MAF?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 01-19-2007, 04:42 PM   #14
69face
69face's Avatar
thanks russel! I did put a diamond plate behind it and i used the reinforcement from a 3/4 pickup. The motor is a 4 bolt 350 w/ 624 thin casting heads 76cc 194in, 150 exhaust the cam is .480 intake/exhaust 270 adv duration 110 centerline comp cam flattop hypereutectic pistons, scat crank pink rods. The tpi is gasket and port matched using a maf system 52mm throttle body. built good enough to just drive and have fun. Im running a th 400 w/ shift kit. The rearend is a stock open end with 3.08 gears. I have two massive turbos that i got off of ebay that i am considering using but i just want it to run for now. also if i go turbo i would like to change over to speed density and use something like megasquirt, because it allows for 20 lbs of boost.
I'M SO SO CAL!
Old 01-22-2007, 11:20 AM   #15
bodydropped
whats up with the rear end setup? u could of 2 link it in my opinion and made a little easier thou
bodydropped is offline   Reply With Quote
Old 01-22-2007, 01:09 PM   #16
Russell
Professional Grade
Russell's Avatar
You might have some trouble getting your TPI to run properly at an idle with that camshaft you bought. I've got a very similar cam in my TPI setup, and have an extremely rich idle (aka, blowing black smoke out the tailpipe). I'd suggest going with something that has specs similar to Comp Cam's XE256H Computer Control cam, it'll run very well in a TPI engine without a ton of chip changes. Aim to build have your powerband from idle through 5200 rpm, cause that is about all you'll get out of that intake with the mods you've listed
Old 01-22-2007, 07:23 PM   #17
69face
69face's Avatar
i was thinking about the 2 link and then i saw n2trux's set up and decided to go in that direction.
I'M SO SO CAL!
Old 01-22-2007, 07:32 PM   #18
kenm78
Broken Down
kenm78's Avatar
What a nice older brother!! "Want to be my big brother"????
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 01-22-2007, 11:25 PM   #19
84slopwaggin
84slopwaggin's Avatar
Heck he could adopt us all. I got a swb gmc that has a rusted front passenger side upper shock mount that I'd like suggestions on. I have no experiece in dealing with this sort of problem. No welding skills or equipment. It's now mounted to a large washer that is screwed to the frame using sheet metal screws. I bought the truck this way. Never even thought to look for rust in these areas. Although I've installed a crate engine I'm really unsure I want to keep this vehicle.
84slopwaggin is offline   Reply With Quote
Old 01-23-2007, 10:12 AM   #20
bodydropped
i see my daily is sorta like kens rear end setup but the bags are on the rear of the leaf springs but im savin up for a ekstensive 2 link setup
Old 01-23-2007, 10:35 AM   #21
N2TRUX
Happy to be here
N2TRUX's Avatar
It looks like you only have one leaf in the pic. Just so you know, my set up uses the top 2 leafs.
Regardless of how it's set up the trucks progress is awesome. Keep the pics coming...
Articles-
"Refining Sierra"
Old 01-24-2007, 03:28 AM   #22
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Nice build-up and good progress.
Looks like a nice place to do build-ups...
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 01-24-2007, 01:39 PM   #23
84 400
Sb 400 club
84 400's Avatar
it is gonna be sweeet when done! what a cool brother you are
1985 C10 LWB Sold
Old 01-24-2007, 03:54 PM   #24
Eyegore
What Hump?
Eyegore's Avatar
OK, I want to know what your little brothers got on ya? That is just to awesome of a build up for a little brother, well at least for my little brother, wouldn't matter anyway he's 48.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 01-24-2007, 04:43 PM   #25
71cheyennezz4
71cheyennezz4's Avatar
Wow your really goin to town on that baby, im awaitin the finish!
71cheyennezz4 is offline   Reply With Quote
