01-22-2007, 05:30 PM | #1 |
Yellow truck club
Your thoughts on rear end choices....
Hey guys
Have a chance at two different rear ends to put into my truck when I install the 4 link 1981 firebird 10 bolt 8.5 posi 3.43 with discs 1999 s10 blazer 4x4 posi 3.42 with discs also has sway bar attached pros / cons Thanks ..Brian
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited Last edited by entourageguy; 01-22-2007 at 06:53 PM. |
01-22-2007, 05:33 PM | #2 |
Re: Your thoughts on rear end choices....
What year Firebird? Second gen should have 8.5" ring gear and I believe 3rd and 4th gen both have 7.5" ring gear.
My 51 project http://www.cardomain.com/ride/2285825 My 68 Camaro project http://www.cardomain.com/ride/2277404/1 |
01-22-2007, 06:18 PM | #3 |
polishing a turd
the firebird one will likely be better, but it depends if it is a 7.5", 8.2" or 8.5"
if you give me an email address, i can send you a chart that shows how to identify it. |
01-22-2007, 07:02 PM | #4 |
Hollister Road Co.
I think the blazer 4x4 is almost a direct bolt in and the correct length
01-22-2007, 07:14 PM | #5 |
The 99 blazer is a great swap, this is off the top of my head, but will be 59" wide, correct width, believe it's either a 7.625" or 8.5" 10 bolt, either way have stood behind decently built V8 swaps in S10's, and will have the Blazer bigger rear discs that are like 11" rotors
01-24-2007, 07:52 AM | #6 |
Yellow truck club
Thanks for the feedback guys. I'm going to go look at the S-10 this weekend.
Brian ...
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
02-07-2007, 10:24 AM | #7 |
How did you make out? (entourageguy) I'm looking for a "cheap" rear for my 1955 chevy 1/2 ton. I can't decide. It will be matched up with a sbc (350) and auto trans which will hopefully one day be switched out for a manual trans. What I'm looking for is disc brakes, and a posi. Any suggestions or pointers on where to look?
02-07-2007, 11:35 AM | #8 |
I know a lot of folks are using rear ends out of the newer F#$D explorers. They are the correct width, come with disc brakes and posi and are cheap.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-07-2007, 05:20 PM | #9 |
The explorer defently look like a posiblity. does anyone have any specs on the rear axles currently in are trucks, I belive they are 59" wide, but does anyone know pinion offset? Or who would make an adapter for a chevy to a ford driveshaft?
02-07-2007, 05:40 PM | #10 |
polishing a turd
just have a custom d/s made for that.
i think the explorers have 31-spline axles, people use them as cheap upgrades for mustang (28-spline) rears. also i don't know if anybody has seen these, but they are good for putting discs on old rears for cheap: http://www.scarebird.com/ or http://www.steeltechsolutions.com/RE...PAGE_CODE.html
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
02-07-2007, 10:32 PM | #11 |
Hey Brian,
You know where my vote go's to!!!! THE BLAZER!!
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
02-07-2007, 10:57 PM | #12 |
So what year blazer rear ends are good fits? I'm looking for a rear end for my '56 too!!!!
1956 Chevrolet 1500 Task Force 2002 Texas Aggie Project Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=212633 |
02-07-2007, 11:09 PM | #13 |
1998 to 2003 Blazers all had rear disc brake. The 4X4 rears are wider then the 2X4's. I used a 2X4 and had to use wheel spacers to get the wheels out more. If I were to do it over again I would us the 4X4.
