01-26-2007, 06:21 PM | #1 |
72 K5 gas tank
I have a 72 K5 that needs a new gas tank was wondering where was the cheapest place to get one and which do I need (steel or poly). Also do I need to get a new sending unit and straps or will my stock one do the job?
01-27-2007, 12:29 AM | #2 |
The Blazer King
Re: 72 K5 gas tank
Ebay has them. All the board venders have them too. All priced pretty close. They do come with straps but if your old ones are good, just use them as the fit is much better. Mine came with the sending unit and lock nut. The filler neck will need to be modified or you need to find a rubber hose that will fit. You will see what i'm talking about when you get your tank.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
01-27-2007, 09:46 AM | #3 |
Re: 72 K5 gas tank
Let me ask this, I have been planning on replaceing mine because it is 1. old and may be somewhat rusty on inside and 2. has a very slight leak from a dent or rock that abraded it and someone attempted a repair but when I started disassembling the blazer last year, I noted that that area was still wet looking, not streaming out but wet. PO welded a small patch in the corner. With all the fitment issues I.m reading, would it be better to repair tis one or is it possible? Thanks
01-27-2007, 02:01 PM | #4 |
Re: 72 K5 gas tank
Most things in auto related topics I will attempt, this does not include repair of fuel tanks, big bang theory.
You might try to look inside your fuel tank by removing the sending unit, then you could add a tank sealant if it is rusty. Someone on the board wrote a very good thread on the topic of tank replacement and his troubles. Most of the problem was due to the fitment of the filler neck. Straps are another issue, save yours if you can. Good luck guys, I'm sure some other guys will have opinions. Just my .02
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-27-2007 at 02:06 PM. |
01-27-2007, 02:50 PM | #5 |
Re: 72 K5 gas tank
You can have a tank recoated on the inside it is supposed to be very effective. A friend had to do that for a Tbird that had no repo available.
01-27-2007, 10:30 PM | #6 |
Re: 72 K5 gas tank
Just buy a new steel tank then take both tanks to a raditior shop and have them solder the old neck on the new tank simple and cheap
01-30-2007, 02:25 PM | #7 |
Cochino_Racing_909
Re: 72 K5 gas tank
Did you find you a tank yet?
Last edited by Angelse68cal; 02-28-2007 at 04:20 PM. Reason: For sale ad in wrong forum by non subscriber |
01-31-2007, 08:56 PM | #8 |
computer illiterate
Re: 72 K5 gas tank
take it to a radiator shop and they will clean and coat it, and can probably fix the leak for you. if it is leaking from a SMALL puncture i would fix it. if it is leaking from rust i would replace it.
72 2wd blazer 72 swb 4x4 |
02-03-2007, 02:00 AM | #9 |
Designated A-hole!
Re: 72 K5 gas tank
This thread is not a wtb, if you have something to sell please subscribe and post it on the parts board.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
02-03-2007, 12:45 PM | #10 |
The LuvShack Garage
Re: 72 K5 gas tank
I have one of each, the 4wd has a poly, the 2wd steel, I like the steel
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
02-03-2007, 12:57 PM | #11 |
Re: 72 K5 gas tank
Mine is poly I don't have to worry about it rusting ever again.
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
02-23-2007, 09:54 PM | #12 |
Re: 72 K5 gas tank
did you install the poly tank youself? any links for this? saw the one for th steel one..but brackets are l shaped for my poly kit..thanks..leon
02-23-2007, 11:08 PM | #13 |
Re: 72 K5 gas tank
I built my own tank, 50 gallons it hurts to fill it, but when I'm out wheeling I know I'll make it home.
02-27-2007, 08:58 PM | #14 |
Re: 72 K5 gas tank
Where did you fit a 50 gal tank?
1972 Chevy LWB K10 Custom/Deluxe Earth first! We'll log the other planet's later. |
02-27-2007, 09:15 PM | #15 |
Re: 72 K5 gas tank
I bought mine on ebay the poly kit .. they are about 200.00 give or take...brothers has the same one listed comes with sender and straps etc and mounts under rear frame rails..
02-28-2007, 09:25 AM | #16 |
Global warming is a myth
Re: 72 K5 gas tank
Yeah, & where are the pictures/dimensions for us to copy it?
Later, Buddy
Henderson, NV 1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!! 1990 K5 with 37's 2003 Discovery SE7 - Wife's |
