Old 01-31-2007, 12:10 AM   #1
[ol'Blue]
[ol'Blue]'s Avatar
how low will i be? in the front.....
..i have DJM2inch drop spring that i cut a half ring off the bottom....
it didnt lower any, it even looked like it raised
im about to buy 3 inch drop spindles.
will it be "TOO low"
i plan on later on, replacing my front coils with bags.
(i have bags and a notch on the rear.)
[ol'Blue] is offline   Reply With Quote
Old 01-31-2007, 12:13 AM   #2
[ol'Blue]
[ol'Blue]'s Avatar
Re: how low will i be? in the front.....
one more picture
Old 01-31-2007, 12:37 AM   #3
dave2953
Dave's not here, man
dave2953's Avatar
There are quite a few guys on here that will say there is no such thing as "too low". I think lower is better, but that seems like a lot for a static drop. Not sure what that would do to things like control arm geometry, ball joints, etc.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 01-31-2007, 01:44 AM   #4
ghetto_superman
ghetto_superman's Avatar
People say that a 3" drop spindle causes rubbing problems... so be aware of that.
-1947 3100 -1968 C10 -1970 K20
ghetto_superman is offline   Reply With Quote
Old 01-31-2007, 02:10 AM   #5
Warren
several people have told me when they put drop spindles on they had to cut a notch in their lower control arms.
Is this always the case say with a 2" or 2 1/2" drop spindle?
Warren
Warren is offline   Reply With Quote
Old 01-31-2007, 04:43 AM   #6
lngbed71
Nothing fits but the oil
lngbed71's Avatar
Naw.....Before I went to bags, I had 3" drop spindles AND cut a half coil. No notching or anything was needed. After I re-installed the springs, it looked raised like you describe, then I realized you need to flatten the bottom of the spring so it rests in the lower arm properly.
Land of the free
Because of the brave
lngbed71 is offline   Reply With Quote
Old 01-31-2007, 05:14 AM   #7
GREASEMONKEY72
GREASEMONKEY72's Avatar
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 01-31-2007, 08:49 AM   #8
[ol'Blue]
[ol'Blue]'s Avatar
so three inch drop spindles WONT rub?
How close will i be to the ground with this static drop, i do not want to not be able to drive it! i have to go to school.
and cant ride the bus cause there are mean bl@ck people.
i have to be able to drive it, without worrying too much about draggingfront.
Old 01-31-2007, 09:24 AM   #9
GWEE
GWEE's Avatar
thats a nice color
1985 GMC ( future plan pro tour build for the wife )
Black 2013 GMC single cab 4/7 drop on 24'' Torque Thrust ST
rules
GWEE is offline   Reply With Quote
Old 01-31-2007, 10:52 AM   #10
lngbed71
lngbed71's Avatar
With a 15' wheel and the drops in place, your overall drop will be around 5" from where the truck was before you started. You will notice a change in ride height as you drive but really no change in suspension performance. I ran wide tires up front and not once did I encounter a rub anywhere. I now have bags and drop spindles and with them flat, I still don't drag anything while parked, 18" wheel and tires get stuffed up in the wells though. No worries about dragging or notching anything with what you want to do.
...JK
Land of the free
Old 01-31-2007, 10:57 AM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by lngbed71 View Post
..... I ran wide tires up front and not once did I encounter a rub anywhere. I now have bags and drop spindles and with them flat, I still don't drag anything while parked, 18" wheel and tires get stuffed up in the wells though.....
...JK
If you run 3" spindles with 15" wheels unless you have very little backspace they will rub against the lip of the A-arm. If you have a minimal backspace they "might" clear. If you go to a tire/wheel larger than 15" you eliminate the problem.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-31-2007, 06:07 PM   #12
[ol'Blue]
[ol'Blue]'s Avatar
what would i have to cut? if it rubs?
