Old 03-01-2007, 04:10 PM   #1
zeitlerusmc
zeitlerusmc's Avatar
ReaD thIs!!!!!
Ok so if you are wanting to lower the rear end of your coil sprung truck, I found a good replacement spring that works great. I lost the springs for my 63 while it sat in my dads back yard for years, in that time I had bought a 2005 jeep wrangler and had lifted it. So when I brought the 63 back to cali I needed to put some springs in the rear, so I put in my old wrangler rear springs. And I was amazed on how well they worked . It sits about 3 inches lower and has a nice spring rate. not only that but stock wrangler springs are one of the most common replaced parts on wranglers since most jeeps get lifted you can find a set of rear wrangler springs for next to nothing! search on craigslist for 97-06 wranglers, And I'll bet money you can find some in your area. I just wanted to pass this along, if you have the money to buy some new lowering springs then by all means go ahead but I'm broke and my truck is a rat rod, so I though some of the other rat guys would like to know! carry on!!!
zeitlerusmc is offline   Reply With Quote
Old 03-01-2007, 04:17 PM   #2
slepysal
slepysal's Avatar
Re: ReaD thIs!!!!!
as always ,a good Marine adapts ! Very nice info !
slepysal is offline   Reply With Quote
Old 03-01-2007, 06:26 PM   #3
rainmans63
rainmans63's Avatar
Re: ReaD thIs!!!!!
Thanks buddy! Good info!
rainmans63 is offline   Reply With Quote
Old 03-01-2007, 10:22 PM   #4
Dadsredwagon
Dadsredwagon's Avatar
Re: ReaD thIs!!!!!
thanks for the tip....
Dadsredwagon is offline   Reply With Quote
Old 03-02-2007, 01:28 AM   #5
Eliasj123
Re: ReaD thIs!!!!!
Thanks for the info..
I'm looking for Wrangler springs as we speak.. I might try Cherokee springs first since I have a set sitting in my garage.. I heard that Cherokee springs are 1.5' taller that Wrangler springs..
2 Questions....
1) Do you know it they or other springs will fit up front??
2) Do they sit in the spring perches or slop around??
Thanks,
Elias
Eliasj123 is offline   Reply With Quote
Old 03-02-2007, 10:46 AM   #6
poorboy
poorboy's Avatar
Re: ReaD thIs!!!!!
I used some Jeep springs in my 67. The only draw back is you can't hau anything with out it bottoming out. I installed some air shocks and it took care of it.
poorboy is offline   Reply With Quote
Old 03-05-2007, 04:51 PM   #7
slepysal
slepysal's Avatar
Re: ReaD thIs!!!!!
Ok I just "won" some on Ebay for $5.00 + shiping will post some before after pics when I install them > Thanks for the rat rod tip.
Old 03-05-2007, 05:05 PM   #8
zeitlerusmc
Re: ReaD thIs!!!!!
Any time brother! told you they were cheap!!!!!!
Old 03-08-2007, 10:36 PM   #9
stepside66
stepside66's Avatar
Re: ReaD thIs!!!!!
hey did you have to do anything when you bolted those in or were they just a straight swap
stepside66 is offline   Reply With Quote
Old 03-08-2007, 11:00 PM   #10
zeitlerusmc
Re: ReaD thIs!!!!!
should be a straight swap I also lost the spring monting hardware so I just bought extra large washers to retain them in place but the stock ones should work fine!
