Old 03-05-2007, 04:24 AM   #1
serrano
serrano's Avatar
What rearend is this?
Can anyone ID this rearend? I just picked up this truck - I don't think rear coils were an option on a '63 C-20... so if that's not stock I figured the rearend might not be either... any help? Sorry for the cheesy cell phone pics.
serrano is offline   Reply With Quote
Old 03-05-2007, 07:54 AM   #2
larry may
Re: What rearend is this?
There may be some numbers stamped on the passangers side axel tube. The numbers will be on the front side and some letters. Wire brush that area post them numbers will help determine what you have there. If the information check both sides of the tube also the drivers side. But most are on the right tube on the front side just left of the center section. Larry
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 03-05-2007, 11:45 AM   #3
serrano
serrano's Avatar
Thanks man I'll get on that this weekend!
Old 03-06-2007, 08:48 PM   #4
624whldr
drive it not trailer it
eaton yes coils on the 3/4 truck are comon. my 66 had that set up with the factory locker
624whldr is offline   Reply With Quote
Old 03-06-2007, 09:01 PM   #5
Kevins65C10
Kevins65C10's Avatar
Thats an Eaton. Not sure of the ring gear diameter. It was used through '72 then phased out in '73 by the 14 bolt. As mentioned above, it could be had with a Detroit No-Spin, and ratios are 4.10-5.13.
Kevins65C10 is offline   Reply With Quote
Old 03-06-2007, 09:28 PM   #6
serrano
serrano's Avatar
I pulled the heads and manifold off today - the motor is a 400 SBC, 2 bolt The rearend may be of the same vintage.
Old 03-06-2007, 10:26 PM   #7
Kevins65C10
That rearend would've come in your truck originally. I would bet thats the original to your truck, if not, it's one identical to the original. 'Cept for those coilovers, those are defineatly not original.
