Old 03-05-2007, 09:21 PM   #1
79blazer
79blazer's Avatar
Intake manifold gasket
I installed an edelbrock intake manifold 4 months ago and for some reason it was leaking. I discovered the bolts loosened up somehow. It was parked for a month and now some of the spark plug may be fowled up, it missing. I bought some 12 point bolts so I can tighten un the hard to reach ones and I think i am going to use a little threadlock this time. I heard you can't use stock gaskets, is this true? What kind do you get? And yes i used black rtv on the ends Thank you
79 Blazer Cheyenne, 2wd 305 3.42 stock
85 Caprice, TBI converted, new 350 crate motor, Monte Carlo SS Wheels, Bilstein shocks,
79blazer is offline   Reply With Quote
Old 03-24-2007, 04:42 PM   #2
AR15DEFENSE
Resident Absorber
AR15DEFENSE's Avatar
Re: Intake manifold gasket
I wouldn't use thread locker on the intake bolts, but do use some permatex thread sealant. this will help keep the oil from collecting in puddles on top of the intake. also, after installing a new intake, you should retorque the bolts after a couple warm up cool down cycles. bolts will usually loosen up after the engine has been hot/cold 2-3 times due to expansion/contraction of metals
The best offense is a better DEFENSE!
AR15DEFENSE is offline   Reply With Quote
Old 03-24-2007, 05:10 PM   #3
79blazer
79blazer's Avatar
I already did it. all 12 bolts have a little theadloack on them. I used "ultra seal" gaskets
