Old 03-08-2007, 10:32 PM   #1
slepysal
slepysal's Avatar
custom dash turn signal lights
Question to those running custom dash inserts: Were or how do you hook up the turn indicator and high beam indicator lights ( on the dash insert) ?
Should I just tap into the turn siganl circuit ?
slepysal is offline   Reply With Quote
Old 03-09-2007, 12:02 AM   #2
72402
Re: custom dash turn signal lights
Yes, but be sure to tap into the wires going to the front lights, so they don't light up when you hit the brakes. You can pick up power for the high beam indicator from the dimmer switch.
72 Cheyenne SWB Fleet/original 402, TH400, buckets & console
65 C10, 350TBI, 700R4 (work in progress)
72402 is offline   Reply With Quote
Old 03-09-2007, 02:26 AM   #3
slepysal
slepysal's Avatar
thanks. I am fabing up my own insert, and will post it when I am done. Thanks again for the tip !
