Old 03-09-2007, 07:15 PM   #1
hewlett2002000
hewlett2002000's Avatar
66 chevrolet body on 76 chevrolet 4x4 frame??
can this be done? i know some modifications would have to be done but would i be getting in way over my head on this one? please help, i only have a couple days to get my hands on this 4x4. thanks for any help or suggestions.
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 03-09-2007, 07:19 PM   #2
62 short step
62 short step's Avatar
Re: 66 chevrolet body on 76 chevrolet 4x4 frame??
It can be done, I've seen some done. Just have to relocate body mounts and various parts.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 03-09-2007, 09:57 PM   #3
zenish
the 66 frame and 76 frame are the same width.it might be easier to swap the front axle and springs into the 66.the two wheel drive suspensions will interchange.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 03-09-2007, 10:03 PM   #4
1969k10stepside
Does your truck have a coil rear suspension,if yes then Id just use the new 4x4 frame,the newer trucks have the body mounts for the cab inside the frame so you will have to use the ones off your truck.Also the frame isnt quite the same so a body lift would be needed.PM Mudder,he did this with a newer frame on a 67 body.
1969k10stepside is offline   Reply With Quote
