04-03-2007, 07:29 PM | #1 |
Floor Pan Install Question
I am replacing most of the floor in the front passenger area. I got a truck floor pan that I am using. The truck floor pan had the rails that were spot welded on.. I cut part of the truck rail off of the floor. I left the flat part spot welded to the floor pan. Question is do I drill out the 20+ spot welds and then have to weld up those holes. Or do I leave the rail on. It does ride about 1/8 higher where it sits, I am sure I could flex it down to weld to outer floor in. with the rail on the floor is noticeably much stronger.
Opinions? |
04-03-2007, 08:18 PM | #2 |
Re: Floor Pan Install Question
Don't follow, any pics.???? J.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
