Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 04-05-2007, 10:16 PM   #1
Critter
Future TOTM Winner
Critter's Avatar
Question Dodge Ram Stereo
Anybody removed the factory stereo from an 06 - 07 Dodge ram? I tore into it some today and it seams like I have to take the dash COMPLETELY apart! I mean, all the way over to the passenger door! Hopefully I am missing something. By the way, mine is a 6speed diesel with the floor shift transfer case if that makes a difference to anybody. Any suggestions?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 04-05-2007, 10:24 PM   #2
combustion
Re: Dodge Ram Stereo
my friend had a shop do his stereo swap on an 06. but he had the nav system taken out, lall they did was take out the plastic faceplate surrounding the stereo, but then again that one had nav in it.. take a pic of it
If it`s 3.73 ratio you will spint the wheel 100 times to the driveshaft`s 373 times.Or,if you`re lazy,you could just spin the wheel once and the driveshaft will spin 3.73 times.Or, 3 and 3/4 turns.And if you`re real lazy,I can sell you a tab for whatever ratio you want.
Or,you could read all the suggestions and try those.It`s been well explained,I think,already.
combustion is offline   Reply With Quote
Old 04-06-2007, 10:12 AM   #3
Critter
Future TOTM Winner
Critter's Avatar
Ask and you shall receive! This is how far I got last night then I quit for fear of breaking something. I am a pretty advanced stereo/electronics guy. Been kind of out of it for the last couple of years though. I was looking around on some other forums and it seams like you have to pull out all the stuff that I have already pulled, then the entire center section (the wood trim along with the grey around the AC controls) will come out. Most of this info was for automatics that had a different kind of floor console, I’m sure they are the same approach though. I took some screws out of this panel from the bottom, but it still won't budge. I’m sure that something pops off using those little clips or something. Everything seems pretty tight; I don’t want to just pull on it. Hopefully someone will make me feel dumb and just tell me that the wood grain pops off or something. Thanks!
Old 04-06-2007, 10:53 AM   #4
67sub
67sub's Avatar
The bezel circled is one piece that snaps on REALLY tight, it MIGHT have two screws coming up from the bottom just to the inside of the cigar lighter and power outlet. About 50% of the trucks have the screws - only way to know for sure is take it apart and look.
2004 Kawasaki KLR
Always looking for a cheap driver
67sub is offline   Reply With Quote
Old 04-06-2007, 03:45 PM   #5
Critter
Future TOTM Winner
Critter's Avatar
Thanks guys. Yeah, elsewere on the web I found out about the screws. Thats why I took it all apart, mine does have them. I guess all thats left for me to do is grow some balls and pull on the panel. I just wanted to confirm this before I started breaking things. I love this board! It has answers for EVERYTHING! While we are on a roll, anybody every altered the Dodge factory Uconnect Blutooth system to work with an aftermarked stereo?
Old 04-06-2007, 06:34 PM   #6
chevyboy55
chevyboy55's Avatar
Critter
Here's a link to a board that has been pretty helpful to me with my wifes Durango.
http://www.dodgetalk.com/forums/tech.php
Great minds think alike,So do ours
chevyboy55 is offline   Reply With Quote
Old 04-07-2007, 07:28 AM   #7
Mudder
Mudder's Avatar
If you can't get it later today I am going to being gong to Union to see some friends of mine. A sister is a repairman in the truck plant and can probably give me an idea what you are up against taking it out. Doubt that she would know the other about the connections. I will see if I can get ahold of her this afternoon.
Mudder is offline   Reply With Quote
Old 04-07-2007, 12:53 PM   #8
Critter
Future TOTM Winner
Critter's Avatar
I appreciate the help. I actually got the panels pulled apart. It was a SOB to get those clips to let go but I eventually got it. Now I am trying to figure out how to connect my factory bluetooth and sirius radio antenna to an aftermarket setup. I will let everyone know how it goes. Thanks again!
Old 04-07-2007, 01:33 PM   #9
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yeah I have done the stereo swap in my cavy and theres a ton of those plastic snap pieces. I felt like I was going to brake the damn thing apart but did not and it came out in one piece! Good luck hope it goes well.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 04-07-2007, 03:31 PM   #10
cdowns
cdowns's Avatar
DODGE?? dont you start by takin the trannie out??
Old 04-08-2007, 06:32 PM   #11
Critter
Future TOTM Winner
Critter's Avatar
No its a 6 speed, not an auto, otherwise yes the trans and the Cummins are the reason that I bought the thing in the first place. The doors will probably fall off and the paint start to peel, but I know I can trust the drivetrain.
