Old 04-11-2007, 03:58 AM   #1
70stroker
70stroker's Avatar
bag
I have a 70 gmc lwb i am thinking abut bagging. Right now it has a 6 7 drop. I would like to to ride atleast that low. ill show a pic at the end. But would like it to go down a little when parked. I DONT want it to lay rocker or frame. I dont care if the crossmember hits the ground when bags are layed out. I do have a few thing i would like to have.
A kit, front and rear or seperate. i dont want to piece parts togther
I would like it to be bolt in mainly, little welding and no serious modding of frame.
a good reliable kit.
thanks guys and pics would be awesome.
Also i have leaves in the rear now. was thinking about gettin a crossmember that the arms connect to and new trailing arms if i could just put the bags on those,
70stroker is offline   Reply With Quote
Old 04-11-2007, 09:19 AM   #2
UP GRADE
one set closer
UP GRADE's Avatar
Re: bag
a lot guys have bought there kits form www.*****************.
UP GRADE is offline   Reply With Quote
Old 04-11-2007, 09:29 AM   #3
Chops_by_Chase
Chops_by_Chase's Avatar
Re: bag
I would look into converting from leaf springs, to trailing arms. there are plenty of aftermarket kits that do this as a bolt in, or you if could find an old chevy that has trailing arms and just take out the trailing arms and crossmembers and use them on yours, then it is an easy bag install. most of this could be a bolt-in
Chops_by_Chase is offline   Reply With Quote
Old 04-11-2007, 11:44 AM   #4
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: bag
If you're willing to go through all the trouble to switch to trailing arms, I would recommend just 4-linking it instead. You'll be happier in the end.
In terms of a "kit", I'd go to ***************** and they have a "build your own kit". That's what I did. They ship quickly, have good product and great customer service, and all for the right price.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 04-11-2007, 02:27 PM   #5
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
Re: bag
Just buy this.http://ridetech.com/productinfo/prod...R21800-LCA.jpg
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 04-11-2007, 02:45 PM   #6
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Re: bag
As far as simplicity goes thats about as easy and as close to "bolt on" as you can get. Add the suicide doors front kit and that's the bulk of what you will need.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 04-11-2007, 02:58 PM   #7
jimmydean
jimmydean's Avatar
Re: bag
Originally Posted by bagged69c10 View Post
What kit is that? I can't find it on the site.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 04-11-2007, 04:04 PM   #8
bagged69c10
Re: bag
Do a search by vehicle and its under rear kits. Heres the link to the page.http://ridetech.com/wizard/results.asp
1965 c-10 long bed
1993 Sierra x-cab
Old 04-11-2007, 04:10 PM   #9
bagged69c10
Re: bag
There is also a similar kit with CPP for a bit cheaper.
http://www.classicperform.com/NewPro...ionPackage.htm
1965 c-10 long bed
1993 Sierra x-cab
Old 04-11-2007, 04:42 PM   #10
70stroker
70stroker's Avatar
Re: bag
does anyone have any pictures of thee trucks bagged. maybe some of ride height and as low as they go? So is that 1700 dollars for the complete rear kit with bags, right? then ill need the front what about compessors and tanks?
thanks
Old 04-11-2007, 11:11 PM   #11
jimmydean
jimmydean's Avatar
Re: bag
thanks
Do a search. 90% of the trucks in this forum is sitting on bags. As far as high/low/ride height. There are a TON of factors involved in "how low" they can go.
You can go all the way to the ground if you want. How much ground do you want? Frame? Pinch welds? Doors? I'm sure if you wanted, you could shorten the doors and get it even lower if you have the $$$.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
