04-23-2007, 11:52 PM | #1 |
Body Bushing/Mount Replacement
Guys and girl,
My truck is in dire need of body bushings. I need to know how bad are the bolts to remove from the body, and if one breaks how F'd am I? I do not have to have to pull the cab off completely right now. What is your guy's input on this? Ryan
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq Last edited by BaddBusa2005; 04-23-2007 at 11:55 PM. |
04-24-2007, 02:36 AM | #2 |
Re: Body Bushing/Mount Replacement
If the back mount bolts break, you can cut holes in the inside of the cab to get to the nuts. On the back ledge behind the seat. Replace then tack weld over the holes you cut.
Front mounts are only in the cab support. You could just cut away enough to get them out and then buy a slip on cab mount and weld it in. Both are worst case scenario's, If PB blaster and heat doesnt work. |
04-24-2007, 09:18 AM | #3 | |
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq |
04-24-2007, 11:18 AM | #4 |
Robert Olson Transport
the nuts sometimes end up moving with the bolt. PB Blaster heat air tools and like the guy who first replied said
04-24-2007, 12:56 PM | #5 |
This is related but I am a little ahead Ryan in doing this. How do you take apart the mounts to replace them with the poly mounts that I already have? I will hopefully get the cab mounts off this week. I need the heavy metal cups. Are those metal sleves just pressed down onto the rubber? I will take a picture of what I am talking about tonight and post it up tomorrow.
Jonathan
1984 Chevy Stepside, 4spd granny, 4 1/2 front/6 inch rear drop. |
04-24-2007, 03:38 PM | #6 | |
04-24-2007, 03:50 PM | #7 |
Right in front of you.
Yes.....
Pinstriping by Josh '78 Chevy Silverado SWB (lowered, 454) '90 Chevy Sport Truck '68 Dodge Charger R/T 1930 Ford Model A |
04-24-2007, 03:56 PM | #8 |
I'll take a torch to one tonight and see if I can get it apart. Seems like a silly design to me! Especially since they are all rusted together! I'll get a picture tonight and post it up.
04-25-2007, 04:06 PM | #9 |
www.73-87chevytrucks.com
The rubber is just pressed onto the metal sleeves, you should be able to pull it off.
If you pop the captured nut from the body, you are going to have to cut a hole in the floor to weld it back on.. I had to do this to my Jimmy.... I think I have some pics.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
