Old 04-26-2007, 07:18 PM   #1
85_SWB
85_SWB's Avatar
What manifolds will work on 86 305?
Ive been looking for some manifolds and cant really find any 305 ones. I can find plenty for 350s tho. Will 350 manifolds work on my 305?
Thanks guys
1985 C10 SWB- *Project*
85_SWB is offline   Reply With Quote
Old 04-27-2007, 02:31 AM   #2
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Re: What manifolds will work on 86 305?
The 350 manifolds will bolt up. But the collector/doughnut gasket area maybe of different diameter. So that means you will need to find the correct size Y pipe or have one made. If you have any type of emissions check you will want to get the correct type manifolds with the air tubes.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 04-27-2007, 09:19 AM   #3
85_SWB
85_SWB's Avatar
im gonna run dual exhaust and have no emissions testing
Old 04-27-2007, 11:43 AM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Some, if not all, 305s have different mounting bolt spacing on one end of the head. The universal crate engines have two sets of holes on them so that either style manifold can be mounted. You can see the two mounting holes on the left side of this crate engine photo:
http://www.lowcostengines.com/images/10067353.jpg
Make sure you measure the distance between the bolts, and that it matches what you have now.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-27-2007, 05:57 PM   #5
SSC's76
No No
SSC's76's Avatar
Thanks guys
The stock LG4 manifolds from sevral different cars will all work as well since they are the same. I question why you not considering a cheap set of headers? Sortys dont make noise if thats the concern.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 04-27-2007, 07:30 PM   #6
85_SWB
85_SWB's Avatar
im low on cash
i just spent $400 on getting the heads redone
and im going to have to spend another $250-$300 on a carb
im looking for performance in this 305 i just want to get it back on the road
i will be building a 350 soon and i plan to swap the heads and carb onto that so i will get headers then
