04-27-2007, 11:05 PM | #1 |
throttle cable adjust?
anybody know if stock style throttle cable has anyway to adjust up slack?i couldn't see a way.the bracket and carb aren't stock.the bracket is adjusted to its last point of no more.
" Never look up a dead dogs butt." |
04-27-2007, 11:19 PM | #2 |
STILL PLAYS WITH TRUX
Re: throttle cable adjust?
If it's the factory throt cable and it has never been messed with you may be able to pull the cable in the cab at the top of the peddle arm towards you and there is a small swedged aluminum barrel at the end of it.
You would take up the slack necessary and duplicate that type of swedge barrel and that should do it. You may be able to obtain a swedge barrel from a speed shop or maybe a bicycle shop "brake cable" or even a fishing bait shop. |
04-28-2007, 03:36 AM | #3 |
glamoros piece o' lowlife
Funny you'd mention that, as a bicycle brake cable is exactly what I'm using for a throttle cable. As a matter of fact it's a bicycle gear shifter cable that operates my choke too, lol
The more I drink, the more I drink, the more I drink... diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express |
04-28-2007, 07:53 AM | #4 |
The Crazy Machanic
so take slack out of my throttle cable all i have ever done was bent the bracket work great and no mods needed. This on a stock bracket of course.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) * 1970 chevelle 2dr sedan Latest update June 24 2007. *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one |
04-28-2007, 11:49 AM | #5 |
yeah,iv'e done similar fixes on old ford trucks before,taking a zip tie or two and using as a spacer to take up slack.i was thinking that those rubber molded ends might twist and release on the stock ones.but i don't think they do.
