Old 04-29-2007, 03:33 PM   #1
karl
karl's Avatar
Shorten driveline ?
http://****************.com/funvideo.html
i need a drivelne for a shortbed 77 2 wheel drive chevy. turbo 350. if i cant find a short driveline can i use one from a longbed and have it cut? my u joint failed because the shop didnt balance the shaft. now its wasted. how much would i expect to pay for a used shaft?.
karl is offline   Reply With Quote
Old 04-29-2007, 03:55 PM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: Shorten driveline ?
yes you can get a long bed shortened. cost i really dont know
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 04-29-2007, 04:00 PM   #3
OJOE
Crew Cut
OJOE's Avatar
should not be a problem to get a used one for about 50.00. where are you located?
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 04-29-2007, 04:09 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
You can purchase decent driveline anywhere from $30.00 to $60.00 depending on the salvage yard. The cost of shortening one, around here is about $100.00 and that included a new U-joint.
piecesparts is offline   Reply With Quote
