Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 06-07-2007, 09:24 PM   #1
JameslovesJammie
God Bless Mr. T
JameslovesJammie's Avatar
2 ohm vs 4 ohm Sub
Can someone explain the difference between 2 and 4 ohm subs? Pros and cons of each.
Like a midget at a urinal...sometimes you must stay on your toes.
JameslovesJammie is offline   Reply With Quote
Old 06-07-2007, 09:47 PM   #2
pcmcobra
pcmcobra's Avatar
Re: 2 ohm vs 4 ohm Sub
Only difference is in the resistance (ohms),
Here's a link I got from google:
http://community.crutchfield.com/forums/thread/890.aspx
You just need to be sure about your amp, if it can push 2 ohm load, if you want to use 2 ohm subs, if that's where you are headed.
There are many many configurations, too many.
Another google:
http://www.google.com/search?hl=en&c...ub&btnG=Search
Wish I could explain a little more clear, but the google results will enlighten you a lot more than what I feel like typing right now.
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 06-07-2007, 10:56 PM   #3
bagged74
its just $$$$$
bagged74's Avatar
as stated earlier, the only reason that they manufacture the subs in different ohm loads is to match them up with your amplifier. This lets you get the most out of your amplifier.
bagged74 is offline   Reply With Quote
Old 06-14-2007, 06:20 AM   #4
brak
brak's Avatar
as stated above, it depends on what your amp is designed to run, and the minimum impedance should be listed on it...
For example:
most amps nowdays can handle a 2 ohm load, so if you have a 2 channel amp that can handle a 2 ohm load, a single 2 ohm sub can be run on each channel.
now if you want to run 2 subs or speakers on a single channel, you would connect (2) 4ohm subs together to achieve 2 ohms.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 06-14-2007, 06:00 PM   #5
72 cheyenne pdx
72 cheyenne pdx's Avatar
To Clarify with (2) 4ohm speakers, wire in parallel and get 2ohms, or you can wire in series and get 8ohms.
72 cheyenne pdx is offline   Reply With Quote
Old 08-15-2007, 01:50 PM   #6
AC72
AC72's Avatar
Any links to diagrams of parralle vs in series?
AC72 is offline   Reply With Quote
Old 08-17-2007, 12:58 PM   #7
Putter
More Cowbell....
Putter's Avatar
Here are a few examples....
Just in case: SVC=Single Voice Coil and DVC=Dual Voice Coil
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
