Old 06-08-2007, 10:37 PM   #1
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
starting issues
My 72 seems to be coming close to some starting issues. A couple times when I've turned the key, it sort of bogs down before it gets started. I was thinking it might be the battery (it is stamped as new in 2001). I put the volt meter on it tonight when I got home. It had 13.85. I started the truck several times until it bogged down and then tested the battery again. This time it showed 12.58. I just wanted to see if ya all thought it might be the battery or the starter before I spend the $ on a battery.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 06-08-2007, 11:10 PM   #2
ABLAZN
Oh..never mind....
ABLAZN's Avatar
Re: starting issues
Bouncy,
Most of the auto parts stores should have a battery tester that puts a draw on like a starter. If the battery test good, then you can start looking else where. I will say that a 6 year old battery should be on its last legs and it might just be a good idea to replace it anyway.
1972 Blazer
-6 inch lift
-35 inch BFG A/T's
Turbo 350
NP-205
454 BB (for now)
MORE TO COME !!!!!! Now going to 2WD!!!!!
Sold.
I got it back after 22 years and did not even know it !!!
THE STORY HERE
Project Low Down Dirty Rat
ABLAZN is offline   Reply With Quote
Old 06-08-2007, 11:27 PM   #3
bouncytruck
SKINNY TIRES RULE!
Re: starting issues
Good call on the tester. I forgot about that. I was thinking the battery might be on it's way out as well. I'll probably start there.
Dang it, I hate resetting all the stereo presets!
bouncytruck 1972 K5
Old 06-08-2007, 11:32 PM   #4
krue
Designated A-hole!
krue's Avatar
Re: starting issues
Better to set the presets, than pull the starter for no reason.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 06-09-2007, 12:10 AM   #5
BLUE THUNDER
BLUE THUNDER's Avatar
Re: starting issues
Sounds like a bad battery. When you tested your battery it may have indicated 13.85 volts, but under a load, (when starting) it probably drops down to 3 or 4 volts. That usually means you have a dead cell in the battery. Autozone can test it for you and let you know for sure. Later, Mario.
BLUE THUNDER is offline   Reply With Quote
Old 06-09-2007, 12:50 AM   #6
EFI70Blazer
Active Member
EFI70Blazer's Avatar
Re: starting issues
Also better to set the presets than be stranded somewhere because it won't start.
Mike T.
Oregon
70 GMC Jimmy 4x4
70 Camaro LS1 plans in the works
71 RS/SS Camaro numbers matching
86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear)
EFI70Blazer is offline   Reply With Quote
