Old 06-24-2007, 05:43 PM   #1
Sadsack
Sadsack's Avatar
Rear Light Fuel Filler?
Ok guys...it's me again! I hope someone can help! I know there was a thread on this a while back by HuggerCST and I love the idea! Putting the fuel filler behind the rear tail light and hinging it to swing down. Didnt think Id ever be doing anything like that so I didnt pay much attention. Welllllll things change! I have all the pics from HuggerCST's thread but cant tell if CST cut the inside of the stake pocket out (if you remove your light and look inthe hole left...the pocket is facing you) or just cut a hole in it and stuck the exhaust tubing through? Anyone else done this...or HuggerCST got anymore pics? I ordered a army surplus Blazer tank yesterday and am itching to get to work! Any pics or help would be greatly appreciated!!! I was gonna go with the side marker door but I think I like this one better!
Sadsack is offline   Reply With Quote
Old 06-24-2007, 06:13 PM   #2
grant's72
grant's72's Avatar
Re: Rear Light Fuel Filler?
this link mite help youhttp://www.classicheartbeat.com/mark...t_gas_door.htm
grant's72 is offline   Reply With Quote
Old 06-26-2007, 11:14 PM   #3
HuggerCST
HuggerCST's Avatar
Here are a few pics, but I didn't get one of the area behind the light before I welded it up. I wish that I would have, but at that time I wasn't sure that it would work. I did have to cut the 1/4 inch tabs off of each side, and some of the stake pocket shown in pic 1. Keep in mind that I did have to use the tail light trim to cover the area of metal that I had to remove at the bottom for clearance. If you have any questions, just ask, and I'll do my best.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 06-26-2007, 11:26 PM   #4
Random Guy
Random Guy's Avatar
Oh wow. That is so awesome. I have just changed my plans completely. Thanks!
CARPE CERVASIUM!
1968 C10 Fleetside LWB
Remember Cthulu is watching you!
Random Guy is offline   Reply With Quote
Old 06-26-2007, 11:34 PM   #5
HuggerCST
HuggerCST's Avatar
Thanks. Here's a few more. I also had to use LEDs to get rid of the bulb socket.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 06-26-2007, 11:38 PM   #6
Chevelle454
Chevelle454's Avatar
That would be sweet...
1972 C10
1972 C20
Chevelle454 is offline   Reply With Quote
Old 06-27-2007, 06:15 AM   #7
GREASEMONKEY72
GREASEMONKEY72's Avatar
*****in dude
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-27-2007, 08:47 AM   #8
lofly'a
lofly'a's Avatar
i have a couple questions HuggerCST? what kind of filler mechanism is that, it is compact and cool, and what holds the door closed, is it held by magnet, screw, or spring loaded? that is one of if not the slickest setup for taillight fill i've seen yet.
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 06-27-2007, 09:45 AM   #9
HuggerCST
HuggerCST's Avatar
The filler is a marine deck filler that I modified. http://www.westmarine.com/webapp/wcs...3&classNum=204
Since I did this another member(Bamm) found one that mounts at an angle, is much cheaper, and looks like it would work better, but I don't have any pics of it. Maybe he will see this and give us more info. I used a universal throttle spring (see the yellow arrows in the pics below) that is mounted at an angle so that it cams over and then holds it open, or closed. I think it needs a little more tension, but I haven't changed it yet. Thanks for the compliments.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 06-27-2007, 11:36 AM   #10
lofly'a
lofly'a's Avatar
thanks for the info. i will be using leds also.
Old 06-27-2007, 12:57 PM   #11
HuggerCST
HuggerCST's Avatar
Here's Bamm's filler neck. http://cgi.ebay.com/ebaymotors/STAIN...spagenameZWDVW
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 06-27-2007, 01:59 PM   #12
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Sadsack...would you be able to provide the link to the build thread? Or could someone else point me in the right direction.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-27-2007, 07:48 PM   #13
72hotrod
72hotrod's Avatar
Hey, HuggerCST, that's some fine work! Does the fill work OK at 1 1/2" or does it burp back some? Did you add a vent tube to the nipple, or is it OK as is? If you had a do-over, would it be worth it to try to fit a 2" ? Thanks for your input, I can only aspire to that level of craftsmanship! My problem is that I am the worst mechanic I know, but the only one I use.
72hotrod is offline   Reply With Quote
Old 06-27-2007, 10:07 PM   #14
HuggerCST
HuggerCST's Avatar
I still don't have the truck on the road, so I haven't tried to fill it yet.(that will be the true test) I started with a 2" filler, but the working space is pretty tight, and my tank neck was 1 & 1/2", so I changed to the smaller one. I did add a vent tube to the filler with a 1/4" pipe elbow and some rubber fuel line going back to the tank. I still have to figure out what to use as a tank vent. Anybody know of a good one? I was planning to use a blazer tank, but it hangs a little low, and the filler comes out in the wrong place, so I've decided to get Fuelcellguy to build me one. If I was to do it again, I'd probably try a angled filler like Bamm's, and I will either find a stiffer spring, or I might add a magnetic latch to keep this one closed tight. I don't think it would come open, but as it is now, it may bounce a little, and I'm not sure how tough the LEDs are. My craftmanship leaves something to be desired, but I cover it up well.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 06-27-2007, 10:16 PM   #15
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
Hey guys. You know what I know as of right now. I bought my filler off ebay a few months ago and haven't progressed far enough on the truck to start the fab work on it. I'll be taking a lot of direction from Hugger and his work. I'll keep you posted but it's looking like 4-6 weeks before I get to that stage.........Jerry
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 06-29-2007, 12:25 AM   #16
SactoJim
SactoJim's Avatar
Hell of a job on that filler........looks like it could've come that way!
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 07-20-2007, 10:57 PM   #17
Mordachai
Fat Fendered Fleetside
Mordachai's Avatar
huggercst- your mod looks great. Wish I would have known about those LEDs when I did my tankfiller. mine is a little more clearance limited cause I worked with the stock light, and I also re-used the in-cab filler, just welded a few pieces of stainless together to get around the curve.
The tank I used is the brothers tank, and it had a vent on it. I wasn't sure if I would need it or not, and I use the truck weekly to haul stuff for my nursery, just with a bedliner hanging in there, haha.
But yeah, I needed to vent mine to not have to trickle fill it, so you might have to as well huggercst. Oh, what was your inspiration for out your fill there? Mine was the old bel-airs!
But yeah, I admire your craftmanship with the spring latch and clean fill area. I still need to finish boxing mine in!
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
radiused fiberglass fender project for 67-72
Mordachai is offline   Reply With Quote
Old 07-21-2007, 03:22 AM   #18
krue
Designated A-hole!
krue's Avatar
Yank's also done this mod and his truck is on the road, maybe he'll chime in.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-21-2007, 09:28 AM   #19
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
When it's on the road, splurge and go to a full-service station and tell 'em to "fill 'er up". Have a camera handy that can video their actions.
I remember when we'd get someone new at the station I worked at "back in the day", and a '56 or 57 Chevy came in for gas. A lot of FoMoCo's had them behind the license plate....and if the car had a Continental kit on it and you had to swing the spare out of the way, it got interesting.
Nice work, man. I like the LED's, too.
Member Nr. 2770
Old 09-15-2007, 07:58 PM   #20
duanes
Hey everyone
Thanks for all the feed back on the fuel filler question. I really appreciate the willingness that you all have to share your Ideas, I hope that as this project continues that I will be able to add something to all of your great ideas. Again thanks, and I will be around to ask more questions. Great site, great people.
Duane
duanes is offline   Reply With Quote
Old 08-21-2009, 12:07 AM   #21
jgrisafi
Velocity Speed Shop
jgrisafi's Avatar
This is a great idea, think it's what I will try.
My Build Thread ..... http://67-72chevytrucks.com/vboard/s...d.php?t=288143
My Garage ..... http://www.hubgarage.com/mygarage/OCD69
jgrisafi is offline   Reply With Quote
Old 01-13-2010, 02:37 PM   #22
crakarjax
crakarjax's Avatar
One thing I would do differently is have the door hinge on top, that way you could easily use a magnet latch because the weight of the door would keep it down. Very nice mod.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 01-13-2019, 03:49 PM   #23
howell57
Where did you get the LED's and again, what size filler tube did you use?
howell57 is offline   Reply With Quote
Old 01-13-2019, 03:53 PM   #24
howell57
Is there a brand name on that filler you got off EBay. Looked , but couldn't find one exactly like that.
Old 01-13-2019, 04:19 PM   #25
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Rear Light Fuel Filler?
New creations in Shelby NC makes these and he sells them through his dad's business at Tommy's truck parts in Shelby. Very good people and they all are 67-72 truck guy's as well.
https://www.facebook.com/search/top/...epa=SEARCH_BOX
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
