07-25-2007, 12:22 AM | #1 |
Texas Big Wig
Lower A-arms from questions to building
Ok, I am going to reverse cup my lower A-arms like this
But I would like to do it with pipe instead My question is, If I have a 7" bag how big of pipe do I need / how much clearance around the bag Edit: I started this thread to get some questions answered, it has so much good info I decided to take the info in it & build a set for myself Last edited by Spray-Bomb; 08-13-2007 at 01:42 PM. |
07-25-2007, 01:50 AM | #2 |
Re: Lower A-arm ???
I'd go with 8", but I've never done it. RE7's don't change diameter (supposedly), so you should be good if you run those.
07-25-2007, 02:11 AM | #3 |
A guy with a truck
Re: Lower A-arm ???
I'd go for "two fingers" of clearance all the way around. Probably a 10" OD pipe.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
07-25-2007, 03:52 AM | #4 |
Re: Lower A-arm ???
what kind of braceing did you use under that arm? are you useing 3/16's plate?
08-01-2007, 02:43 PM | #6 |
On the fast track to nowhere..
Re: Lower A-arm ???
If you haven't done this yet, I am using 8". Te RE7s diameter actually gets smaller as it lifts. I have about 1/2" of clearance. I don't think you could fit anything bigger, 8" almost takes up the whole control arm.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
08-01-2007, 03:30 PM | #7 |
Re: Lower A-arm ???
08-01-2007, 11:36 PM | #8 |
Texas Big Wig
Re: Lower A-arm ???
Thats what I thought
I haven't started to build yet, but I will keep you posted Hey 88, do you have any pics ??? |
08-02-2007, 08:45 AM | #9 |
Re: Lower A-arm ???
I'm not finished but here's an idea. I just need to weld the plate to the bottom.
08-02-2007, 10:36 AM | #10 |
Texas Big Wig
Re: Lower A-arm ???
Wow thats close, I'll be glad to see how this works
How deep did you make yours, I was thinking of making mine a inch deeper that stock |
08-02-2007, 10:53 AM | #11 |
Re: Lower A-arm ???
I made it 3 inches from the top flat surface of the control arm. The bags have a minimum height of 2.8 inches so this will let the arm contact the upper plate before the bag bottoms out. If I wanted good lift I wouldn't do it this way but I'm looking for the lowest ride height I can get.
08-08-2007, 12:25 AM | #12 |
Texas Big Wig
Re: Lower A-arm ???
Well I went and saw Mark (FuelCellGuy) today & he gave me a piece of 8" i.d. pipe for my A-arms Man I love that guy, too bad he's always working
08-08-2007, 08:27 AM | #13 |
Re: Lower A-arm ???
Cool! Get to work
08-08-2007, 02:34 PM | #14 |
Re: Lower A-arm ???
i dont mean to sound stupid but with is it that you guys are doing and why?
1985 GMC ( future plan pro tour build for the wife ) Black 2013 GMC single cab 4/7 drop on 24'' Torque Thrust ST rules |
08-08-2007, 02:41 PM | #15 |
Re: Lower A-arm ???
There's never a stupid question here. Long story short we go from this height
To this height It's not for everyone, but we enjoy it. You can see more detailed progress in my build thread if you're interested.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting Last edited by BACKYARD88; 08-08-2007 at 02:43 PM. |
08-08-2007, 02:44 PM | #16 |
Re: Lower A-arm ???
do you have anymore pics of the front of the truck. with the lower A-arm installed
08-08-2007, 02:50 PM | #17 |
Re: Lower A-arm ???
Like this?
Here's one with the air at full lift.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting Last edited by BACKYARD88; 08-08-2007 at 02:51 PM. |
08-08-2007, 03:10 PM | #18 |
Re: Lower A-arm ???
oh ok i see what yall are doing. its to get it even lower.
08-08-2007, 03:12 PM | #19 |
Re: Lower A-arm ???
did you cut your engines crossmember?
08-08-2007, 03:15 PM | #20 |
Re: Lower A-arm ???
Yes, sectioned it 1.25 inches.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting Last edited by BACKYARD88; 08-08-2007 at 04:01 PM. |
08-08-2007, 03:40 PM | #21 |
Re: Lower A-arm ???
nice is there a step by step on how to do that
08-08-2007, 03:53 PM | #22 |
Re: Lower A-arm ???
08-08-2007, 03:59 PM | #23 |
Re: Lower A-arm ???
I'm not sure if anyone has done a how-to. I haven't.
I'm not sure about everyone else, but I set mine up with a pocket so I can have an extremely low ride height. A 3" pocket gives me a 3" lower ride height Got any pics of your set up?
08-08-2007, 04:04 PM | #24 |
Re: Lower A-arm ???
this is my truck
08-08-2007, 04:20 PM | #25 |
Re: Lower A-arm ???
how thick is the pipe you guys are useing? 3/16 or 1/4"
