Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 08-14-2007, 01:24 AM   #1
Pyrotechnic
Pyrotechnic's Avatar
Amplifier Power Connection Point
For years I've understood the main power cable for amplifiers to connect to the positive terminal of the battery. On a 73-87, the main path from the output terminal of the alternator to the battery is a 10 gauge wire thats meant only to charge the battery. It doesn't need to be huge because the battery doesn't charge instantly.
If you had the truck running and the sound system turned up with the amplifiers connected to the battery, would that be forcing all that current to be drawn from that 10 gauge charging wire ?
I know most modern cars have the alternator wired directly to the battery, which is why the connection point at the battery is fairly common knowledge, I'm just wondering if special care should be taken when dealing with the wiring in these trucks.
In my 78 I had a small 35Wx2 amp connected to the battery with 10 gauge, and I never had a problem, but of course the output and current draw of this amp is quite small.
Pyrotechnic is offline   Reply With Quote
Old 08-14-2007, 11:13 PM   #2
canadianc-10
Re: Amplifier Power Connection Point
if im reading your question right.. an amp is no different then any add on with high current loads likeoff road lights etc. when connected to the battery they run off the battery whether the engines on or not.
canadianc-10 is offline   Reply With Quote
Old 08-15-2007, 01:07 AM   #3
AceX
>130dB Moderator
AceX's Avatar
Connect the power to the posetive terminal on the battery. Run a short, matching ground. Wire up the remote. Have a beer.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 08-26-2007, 09:40 PM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Exactly! Sounds good to me.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
